17257 讨论
Error 10232 - Problem with Qsys generated code...
名誉分销商 II
1,396 次查看
I have a QSYS based system which includes the Hard PCIe core and some of my own logic to drive it.
The design's targeted at a Cyclone IV GX '22.
When I generate the system in Quartus 11.0 the Qsys system generates and I can build the design OK. There are problems with PCIe interrupt handing in 11.0 so I need to build on a later version.
However if I generate the same Qsys system in 11.1 sp2 then try to build the FPGA I get Error 10232.
It looks like it's the same problem as here...
http://www.alteraforum.com/forum/showthread.php?t=3251
..however this is happening in multiple places in the generated code so the fix given there isn't an option.
Has anyone else seen this or know of a workaround?
Thanks for any pointers,
Nial.
0 项奖励
3 回复数
名誉分销商 II
602 次查看
it's definitely worth filing a Service Request on this issue!
0 项奖励
名誉分销商 II
602 次查看
Did you find any answer for this 10232 error please ?
Thx
0 项奖励
名誉分销商 II
602 次查看
--- Quote Start ---
Thx
--- Quote End ---
Yes, search the forums for 10232 and I have a post in a thread Qsys which explains the solution.
Nial.
0 项奖励
回复
