- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
Hello guys,
it's been a really long time for me without coding in VHDL. I need a stepper motor controller for my nios2 based project so i thought it's best to implement it in FPGA which led me to write the code bellow: library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_unsigned.all; entity stepper_motor_controller is port ( reset_n, clk, f_hn: in std_logic; mc: in std_logic_vector (1 downto 0); steps: out std_logic_vector (3 downto 0)); end entity; architecture behav of stepper_motor_controller is signal halffull :std_logic_vector (3 downto 0); begin process (reset_n,mc(1),f_hn) begin if (reset_n = '0') then halffull <= (others=>'0'); elsif (mc(1) = '0') then halffull <= (others=>'0'); elsif (f_hn = '0') then halffull <= "0001"; else halffull <= "0011"; end if; end process; process (clk) begin if (rising_edge(clk)) then if (mc(0)= '1') then halffull <= halffull(0) & halffull(3 downto 1); --rotate right else halffull <= halffull(2 downto 0) & halffull(3); --rotate left end if; else halffull <= halffull; end if; end process; steps <= halffull; end architecture; unexpectingly, i ended up having the following error msg: error (10327): vhdl error at stepper_motor_controller.vhd(16): can't determine definition of operator ""="" -- found 0 possible definitions i'll really appretiate it if someone could point out the reason for this error or suggest a modification to get over it Thx in advance, good day ;)- Etiquetas:
- Intel® Quartus® Prime Software
Enlace copiado
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Hi anis,
I saw your code and there are missing single cots (') in the IF statement, like "if (MC(0)= 1)", that should be "if (MC(0)= '1')" because you are comparing a bit and not an integer. Good luck!!- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
thx leonardo, the cots are not problem..i've updated the code just to make sure
ps/ single cots are used for vectores not bits but thx anyway :D- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
I don't know, but I always use single cots to bit and double cots to vector. Another thing I saw is that you are attributing a value of a bit to a vector of bits when you do "halffull <= '0';". That is what I am seeing until now.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
here you go, code is updated, error is still driving me crazy :shock:
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Well, I copy your code and run Analysis and Synthesis in my PC changing " for ' where is bit and ' to " where is vector and the only error was that it doesn't recognize the ror command. Where does this error occur during Analysis and Synthesis or during the Fitter?
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
the problem occured during compilation of the code. i get over it by taking another working code and changing it line by line to this one (the strangest technique lol). i had the "ror" problem then and it seems to be related to the fact that this operator isn't compatible with std_logic_vectors. so to avoid messing with vectors types i just used concatenation to perform rotate actions which works just fine.
now i'm debugging the program from some constant drivers issues. thx for your efforts leonardo i owe you one ^^- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Ok!! Good luck!!!
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
If I understand right, you have removed the original code which the question title is referring to. Deleting the post completely would be similarly meaningful.
Apart from this strange practice, I also wonder you checked the code line by line, although Quartus shows you the line where the error occured? Now the code is still useless, because it's not generating any output.- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
I would also suggest to drop the non standard ieee.std_logic_unsigned.all library and use ieee.numeric_std.all instead with its signed and unsigned types.
- Marcar tema como nuevo
- Marcar tema como leído
- Favorito
- Suscribir
