17254 Discussions
Error 10500 near text ¨´¨; epecting ¨;
Hello all,
I need help,
I can see any reasons why I am getting en error:
Error (10500): VHDL syntax error at Adder.vhd(49) near text ¨´¨; expecting ¨;¨
The error points to line: outBuffer(8) <= ´0´; in my code.
Here is my complete codes:
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
use ieee.std_logic_unsigned.all;
use ieee.numeric_std.all;
use ieee.std_logic_misc.all;
entity adder8bits is
port (
clk : in std_logic;
inputSignal0 : in std_ulogic_vector(7 downto 0);
inputSignal1 : in std_ulogic_vector(7 downto 0);
outSignal : out std_ulogic_vector(8 downto 0)
end entity adder8bits;
architecture rtl of adder8bits is
signal bitBuffer0 : std_ulogic_vector(7 downto 0);
signal bitBuffer1 : std_ulogic_vector(7 downto 0);
signal outBuffer : std_ulogic_vector(8 downto 0);
signal signalBuffer0 : std_ulogic_vector(7 downto 0);
signal signalBuffer1 : std_ulogic_vector(7 downto 0);
signal count : integer;
begin
process(clk,signalBuffer0,signalBuffer1,bitBuffer0,bitBuffer1,outBuffer,outSignal)
begin
if rising_edge(clk) then
signalBuffer0(7 downto 0) <= inputSignal0(7 downto 0);
signalBuffer1(7 downto 0) <= inputSignal1(7 downto 0);
count <= 0;
outSignal <= outBuffer;
elsif falling_edge(clk) then
bitBuffer0(7 downto 0) <= signalBuffer0(7 downto 0) xor signalBuffer1(7 downto 0);
bitBuffer1(7 downto 0) <= signalBuffer0(7 downto 0) and signalBuffer1(7 downto 0);
outBuffer(7 downto 0) <= bitBuffer0(7 downto 0);
for count in 0 to 6 loop
if bitBuffer0(count) = ´0´ and bitBuffer1(count) = ´1´ and bitBuffer0(count+1) = ´0´ then
bitBuffer0(count+1) <= ´1´;
outBuffer(count) <= ´0´;
elsif bitBuffer0(count) = ´0´ and bitBuffer1(count) = ´1´ and bitBuffer0(count+1) = ´0´ then
bitBuffer1(count+1) <= ´1´;
elsif bitBuffer0(count) = ´1´ and bitBuffer1(count) = ´1´ and bitBuffer0(count+1) = ´0´ then
outBuffer(count) <= ´1´;
end if;
end loop;
if bitBuffer0(7) = ´0´ and bitBuffer1(7) = ´1´ then
elsif bitBuffer0(7) = ´1´ and bitBuffer1(7) = ´1´ then
end if;
end if
end process;
end rtl;
I have plenty more of the same error.
A new pair of eyes will be helpful, to see where is causing the error.
Thank you.
use ' not ´
another note:
These two libraries have conflicts. You should only use numeric_std (because std_logic_arith is not standard VHDL).
another note - you cannot use both rising_edge and falling_edge in the same process for synthesisable VHDL inside FPGAs.
Thank you..
I knew it might may have been because of ¨´¨.
I am using a Mac keyboard that provides for ´.
