17267 Discussions
Error 10500 when using process and port maps for bitwise operations
Hello all,
I am trying to incorporate bitwise operations into a file with an 8 bit carry look ahead adder. I declare the entity doing the operations as a component in the file with the carry look ahead adder. However, when I compile I get the following error:
Error (10500): VHDL syntax error at <location> near text ";"; expecting ":=", or "<=" Error (10500): VHDL syntax error at <location> near text "port"; expecting "(", or "'", or "."
If I remove the whole process statement process(ops) leaving operate: operations port map (a(5 downto 0), b(5 downto 0), opc, ops, opr); , it compiles fine. I even tried to do the port maps with signals but that still did not help my problem. Can someone figure out what's the issue?
library IEEE; use IEEE.std_logic_1164.all; use IEEE.numeric_std.all; entity cla4_add_subtract is port(a, b: in std_logic_vector(7 downto 0); cin: in std_logic; subtract: in std_logic; sum: out std_logic_vector(7 downto 0); cout: out std_logic; ops: in std_logic; opc: in std_logic_vector(2 downto 0); opr: out std_logic_vector(5 downto 0); d1, d2, d3, d4: out std_logic_vector(6 downto 0); overflow: out std_logic); end cla4_add_subtract; architecture cla4_add_subtract_arch of cla4_add_subtract is component mux2to1 port( a, b: in std_logic_vector(7 downto 0); sel: in std_logic; y: out std_logic_vector(7 downto 0)); end component; component claFour port( a, b: in std_logic_vector(7 downto 0); carryin: in std_logic; sum: out std_logic_vector(7 downto 0); cgout, cpout, overflow: out std_logic); end component; component operations is port( a,b: in std_logic_vector(5 downto 0); opcode: in std_logic_vector(2 downto 0); start: in std_logic; result: out std_logic_vector(5 downto 0) ); end component; component binbcd port(bin : std_logic_vector(7 downto 0); p: out std_logic_vector(9 downto 0)); end component; component printOut port(digit: in std_logic_vector(3 downto 0); print: out std_logic_vector(6 downto 0)); end component; signal carry: std_logic; signal b_not: std_logic_vector(7 downto 0); signal b_actual: std_logic_vector(7 downto 0); signal sum_i: std_logic_vector(7 downto 0); signal result: std_logic_vector(9 downto 0); signal padder: std_logic_vector(3 downto 0); signal int : integer; begin b_not <= not b; carry <= cin; MUX_SUB: mux2to1 port map (b, b_not, subtract, b_actual); ADD0: claFour port map (a, b_actual, carry, sum_i, cout, open, overflow); sum <= sum_i; int <= to_integer(signed(sum_i)); process(int) begin if int < 0 then d4 <= "1111110"; else d4 <= "1111111"; end if; end process; segment: binbcd port map(sum_i, result); padder(3) <= result(8); padder(2) <= result(9); padder(1) <= '0'; padder(0) <= '0'; print1: printOut port map (padder(3 downto 0), d1); print2: printOut port map (result(7 downto 4), d2); print3: printOut port map (result(3 downto 0), d3); process(ops) begin if ops = '1' then operate: operations port map (a(5 downto 0), b(5 downto 0), opc, ops, opr); end if; end process; end cla4_add_subtract_arch; library IEEE; use IEEE.std_logic_1164.all; entity printOut is port(digit:in std_logic_vector(3 downto 0); print:out std_logic_vector(6 downto 0)); end printOut; architecture parch of printOut is begin process(digit) begin case digit is when "0000"=> print <="0000001"; -- '0' when "0001"=> print <="1001111"; -- '1' when "0010"=> print <="0010010"; -- '2' when "0011"=> print <="0000110"; -- '3' when "0100"=> print <="1001100"; -- '4' when "0101"=> print <="0100100"; -- '5' when "0110"=> print <="0100000"; -- '6' when "0111"=> print <="0001111"; -- '7' when "1000"=> print <="0000000"; -- '8' when "1001"=> print <="0000100"; -- '9' when others=> print <="1111111"; end case; end process; end parch;
You cannot put a component instantiation in a process.
A component is like a microchip. Putting a port map in a process is like asking a circuit to add/remove a chip while the circuit is running, which is impossible.
