Hi all, again.
I'm trying to follow coding guide lines, but i'm failing with this particular PROCESS call. I can't see how to form the process_button1_handler into anything like the Altera Template examples that allow registers to be properly created.:confused: I realise that the code for process_button1 is very clunky, that will be reworked later. In addition, does QII have a predefined TRUE and FALSE? help?
Error (10818): Can't infer register for "button1_go" at keyfob_top.vhd(52) because it does not hold its value outside the clock edge.
Error (10818): Can't infer register for "process_button1_handler:counter" at keyfob_top.vhd(52) because it does not hold its value outside the clock edge
code as follows:
library ieee;
use ieee.std_logic_1164.all;
entity keyfob_top is
port
pin_clk: in std_logic; -- our input clock
pin_button1: in std_logic; -- user button, fires a signal1
pin_led1_output: out std_logic; -- user sees that a button has been pushed
pin_ir_output: out std_logic -- IR output signal
end keyfob_top;
architecture led_behaviour of keyfob_top is
signal baud_tick : std_logic := '0'; -- baud rate delay
signal button1_go : std_logic := '0'; -- start sending button1 press information
constant button_up : std_logic := '0'; -- button has not been pressed
constant button_down : std_logic :='1'; -- button has been pressed
constant led_on : std_logic := '1';
constant led_off : std_logic := '0';
constant true : std_logic := '1';
constant false : std_logic := '0';
begin
-- create our baud_rate clock
process_baud_clock : process(pin_clk, baud_tick)
variable counter1 : integer range 0 to 100 := 0;
constant baud_rate : integer := 3; -- baud rate divider
begin
if(rising_edge(pin_clk)) then -- do we have a new rising edge?
counter1 := counter1 + 1; -- incrament the counter
if(counter1 > baud_rate) then
counter1 := 0; -- reset the counter
if(baud_tick = '1') then
baud_tick <= '0'; -- toggle state
else
baud_tick <= '1'; -- toggle state
end if;
end if;
end if;
end process process_baud_clock;
-- button1 process handler (and debounce)
process_button1_handler : process(pin_button1, baud_tick)
variable counter : integer range 0 to 100 := 0;
constant delay : integer := 3;
variable delay_ongoing : std_logic := false;
begin
-- has a button just been pressed
if(rising_edge(pin_button1)) then -- (line52)has button just been pressed
delay_ongoing := true;
button1_go <= button_down;
-- this is a baud tick, continue
elsif((delay_ongoing = true)) then -- are we counting a delay?
if(counter = 0) then -- button has just been pressed, start
counter := counter + 1;
elsif(counter = delay)then -- end of debounce, reset everything
counter := 0;
delay_ongoing := false;
button1_go <= button_up;
else -- we are in the middle of debounce, continue
end if;
end if;
end process process_button1_handler;
-- baud tick handler
process_button1 : process(baud_tick, button1_go)
variable button1_bits_left : integer range 0 to 10 := 7; -- bits left to transmit for button1 press
variable button1_status : std_logic := '0';
begin
if(rising_edge(baud_tick)) then
if((button1_bits_left < 7) or -- we are already servicing it
(button1_go = button_down and button1_bits_left = 7)) then -- start servicing it
case button1_bits_left is -- choose which bit to send out
when 7 => -- our first bit
pin_ir_output <= led_off;
pin_led1_output <= led_on; -- show user what is going on
when 6 =>
pin_ir_output <= led_on;
when 5 =>
when 4 =>
when 3 =>
when 2 =>
when 1 =>
when 0 => -- our last bit
pin_led1_output <= led_off; -- show user what is going on
--button1_go_write(button_up);-- signal we have finished with teh button press
when others => null;
end case;
if(button1_bits_left > 0) then
button1_bits_left := button1_bits_left - 1; -- decrament by one
else
button1_bits_left := 7; -- reset our bit counter;
end if;
end if;
end if;
end process process_button1;
end led_behaviour;
yours, in need of help, bag it.
Some of your constructs can never work in logic hardwire design, e.g. operating a counter without an edge sensitive condition. (in the second part of process_button1_handler).
What update rate do you expect for the counter? Where should it come from? You can possibly have both ansynchronous and synchronous set for a register value like button1_go. But to be recognized as an asynchronous preset, the condition must take precedence over the synchronous action, but you have reversed the precedence. --- Quote Start --- In addition, does QII have a predefined TRUE and FALSE? --- Quote End --- VHDL has it for the boolean data type.
