17253 Discussions
Error: Assert failure at ACLIntrinsics.cpp(1605)
yjian16
When I use the aoc to compile my opencl file ,I meet the compiler errors as below:
there is no detailed information for the error. I do not know what cause the problem.
HRZ
Valued Contributor III
Can you post your kernel so that we would replicate the issue? If not, can you attach the *kernel_name*.log and quartus_sh_compile.log files? The latter might not exist if the process is crashing in the OpenCL to HDL conversion.
