17253 Discussions
Error: Can not generate netlist output
I'm trying to compile a program, I got this error when I get to final stage EDA netlist writter:
Error: Can not generate netlist output files Because the license for encrypted file "C :/ Users/Desktop/AN374_IP/AN374_IP/_restored/incremental_db/compiled_partitions/namefile.map.atm" is not available
please help me
HI,
Are you using any IP Core? It looks like you are trying to use an IP Core without licence.
Hi shikataleonardo
of what license you talking about?? the license quartus?? if I do not license the compilation stops since the beginning
License to use de IP Core. Each IP Core has an especific license file to enable the netlist generation. That is what I know. There is the option to evaluate the IP Cores from Altera, but only works with the FPGA conected to the PC.
hi
i resolve the problem but now i have this warning
Warning: Can't generate output files. Specify command-line options to generate output files, or update EDA tool settings using GUI or Tcl script.
can you help me pleazzz
Go to your project settings, go to the EDA Tool Settings tab, and check that "None" is selected everywhere. You shouldn't need to generate a netlist output in most cases (and if you do, then you'll need to buy the licenses for all the licensed IPs that you are using in your project).
