17253 Discussions
vhdl signed multiplication
how to convert the following unsigned 8x8 multiplication program to "signed 8x8 multiplication"...??? library IEEE; use IEEE.std_logic_1164.all; entity vmul8x8p is port ( X: in STD_LOGIC_VECTOR (7 downto 0); Y: in STD_LOGIC_VECTOR (7 downto 0); P: out STD_LOGIC_VECTOR (15 downto 0) ); end vmul8x8p; architecture vmul8x8p_arch of vmul8x8p is function MAJ (I1, I2, I3: STD_LOGIC) return STD_LOGIC is begin return ((I1 and I2) or (I1 and I3) or (I2 and I3)); end MAJ; begin process (X, Y) type array8x8 is array (0 to 7) of STD_LOGIC_VECTOR (7 downto 0); variable PC: array8x8; -- product component bits variable PCS: array8x8; -- full-adder sum bits variable PCC: array8x8; -- full-adder carry output bits variable RAS, RAC: STD_LOGIC_VECTOR (7 downto 0); -- ripple adder sum begin -- and carry bits for i in 0 to 7 loop for j in 0 to 7 loop PC(i)(j) := Y(i) and X(j); -- compute product component bits end loop; end loop; for j in 0 to 7 loop PCS(0)(j) := PC(0)(j); -- initialize first-row "virtual" PCC(0)(j) := '0'; -- adders (not shown in figure) end loop; for i in 1 to 7 loop -- do all full adders except last row for j in 0 to 6 loop PCS(i)(j) := PC(i)(j) xor PCS(i-1)(j+1) xor PCC(i-1)(j); PCC(i)(j) := MAJ(PC(i)(j), PCS(i-1)(j+1), PCC(i-1)(j)); PCS(i)(7) := PC(i)(7); -- leftmost "virtual" adder sum output end loop; end loop; RAC(0) := '0'; for i in 0 to 6 loop -- final ripple adder RAS(i) := PCS(7)(i+1) xor PCC(7)(i) xor RAC(i); RAC(i+1) := MAJ(PCS(7)(i+1), PCC(7)(i), RAC(i)); end loop; for i in 0 to 7 loop P(i)
I can help if you could attach the file , your vhdl code text is all in back to back lined up.
--- Quote Start ---
--- Quote End ---
library IEEE;
entity vmul8x8p is
end vmul8x8p;
begin
end MAJ;
begin
process (X, Y)
end loop; end loop;
end loop;
end loop;
end loop;
RAC(0) := '0';
end loop;
P(i) <= PCS(i)(0); -- first 8 product bits from full-adder sums
end loop;
for i in 8 to 14 loop
P(i) <= RAS(i-8); -- next 7 bits from ripple-adder sums
end loop;
P(15) <= RAC(7); -- last bit from ripple-adder carry
end process;
end vmul8x8p_arch;
sir now can you please tell how to convert the above code to signed multiplication.....,
the easiest way is to use the arithmetic libraries:
library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; ..... signal a, b : signed(7 downto 0); signal c : signed(15 downto 0); .... c <= a * b;
sir we need to use this signal statement in testbench {.tb} or in .vhd program itself..?
i don know where to use the 'conditions' for signed multiplication
i get output for unsigned correctly... but signed only..?
what are you talking about?
my code works for synthesisable VHDL and testbenches.
sir i am a newbie to vhdl..(just now in learning stage)
can u please upload a code for VHDL SIGNED MULTIPLICATION (16-BIT or 8-BIT)
the code which i created is performing only signed multiplication.
The code I posted does that. I sugges you read a VHDL tutorial if you need help writing VHDL.
ok sure sir.., can you please include your idea (code) in my code which i posted..,
please help me sir..,
oh my god ...,pls anyone edit my code ..,
You need to cast your inputs from STD_LOGIC_VECTOR to SIGNED, use Tricky's code and cast result back to STD_LOGIC_VECTOR.
