17253 Discussions
Error Creating Project Failed to Execute: ./create-this-app --no-make
Hi All,
I am having a problem with an error message "Error Creating Project Failed to Execute: ./create-this-app --no-make" when I tried to create a new project using "Nios 2 Application and BSP Template". I tried to change the path if that caused the problem but I was getting the same message. I have also tried to Run Nio 2- Eclipse as Administrator, yet no change. Anyone had similar issues. Thank you in advance.
Are you working on a local drive or a network attached drive? Windows or Linux?
I've had similar problems on Windows when trying to work on networked drives. Try working on a local drive.
Cheers,
Alex
