17252 Discussions
Error:Port "cg" does not exist in macro function "ADD0"
So i got 8 error while compiling this 4 bit Carry-lookahead adder. I got the above error for ports cg and cp in macro functions ADD0-ADD3. For my code check the attachments. Edit: Here i've copied the code in:
--- Quote Start ---
library IEEE;
use IEEE.std_logic_1164.all;
entity cla4 is -- 4-bit CLA structural model: top entity
port( a, b: in std_logic_vector(3 downto 0);
carryin: in std_logic;
sum, ch, cq: out std_logic_vector(3 downto 0);
cgout, cpout, overflow: out std_logic);
end cla4;
architecture arch of cla4 is
component fagp -- component declaration
port( a, b, cin: in std_logic;
sum, cg, cp: out std_logic);
end component;
component cla_logic -- component declaration CLA-generator
port( g, p: in std_logic_vector(3 downto 0);
cin: in std_logic;
c: out std_logic_vector(2 downto 0);
cgout, cpout: out std_logic);
end component;
signal carry: std_logic_vector(3 downto 0); --local signals
signal cg, cp: std_logic_vector(3 downto 0);
signal cout: std_logic;
begin
carry(0) <= carryin;
ADD0:
fagp
port map (a(0), b(0), carry(0), sum(0), cg(0), cp(0));
ADD1:
fagp
port map (a(1), b(1), carry(1), sum(1), cg(1), cp(1));
ADD2:
fagp
port map (a(2), b(2), carry(2), sum(2), cg(2), cp(2));
ADD3:
fagp
port map (a(3), b(3), carry(3), sum(3), cg(3), cp(3));
--generate carries from
--propagate and generate values
--from full_adder_g_p_g_p
CLA:
cla_logic
port map(cg, cp, carryin, carry(3 downto 1), cout, cpout);
cgout <= cout;
overflow <= carry(3) xor cout;
end arch;
--- Quote End ---
--- Quote Start ---
library IEEE;
entity cla_logic is
port(
G, P: in std_logic_vector(3 downto 0);
CIN: in std_logic;
C: out std_logic_vector(2 downto 0); -- “internal” carry
CGOUT, CPOUT: out std_logic);
end cla_logic;
architecture arch of cla_logic is
begin
C(0) <= G(0) or (P(0) and CIN);
C(1) <= G(1) or (G(0) and P(1)) or (CIN and P(0) and P(1));
C(2) <= G(2) or (G(1) and P(2)) or (G(0) and P(1) and P(2)) or (CIN and P(0) and P(1) and P(2));
CGOUT<= G(3) or (G(2) and P(3)) or (G(0) and P(2) and P(3)) or (G(0) and P(1) and P(2) and P(3)) or (CIN and P(0) and P(1) and P(2) and P(3));
CPOUT<= (P(3) and P(2) and P(1) and P(0));
end arch;
--- Quote End ---
--- Quote Start ---
library IEEE;
entity fagp is
sum, g, p: out std_logic);
end fagp;
architecture arch of fagp is
begin
sum <= a xor b xor cin;
p <= a and b; --complete this
g <= a or b; --complete this
end arch;
--- Quote End ---
Any Ideas??
