I am using the quartus prime lite edition(20.1).
I ran the waveform program. But I received the warning and error message.
I don't know how can i solve this problem.
plz give me some help.
Determining the location of the ModelSim executable...
Using: C:\intelFPGA_lite\20.1\modelsim_ase\win32aloem
To specify a ModelSim executable directory, select: Tools -> Options -> EDA Tool Options
Note: if both ModelSim-Altera and ModelSim executables are available, ModelSim-Altera will be used.
**** Generating the ModelSim Testbench ****
quartus_eda --gen_testbench --tool=modelsim_oem --format=verilog --write_settings_files=off mux_2_1 -c mux_2_1 --vector_source="D:/report/Waveform.vwf" --testbench_file="D:/report/simulation/qsim/Waveform.vwf.vt"
Info: *******************************************************************
Info: Running Quartus Prime EDA Netlist Writer
Info: Version 20.1.0 Build 711 06/05/2020 SJ Lite Edition
Info: Copyright (C) 2020 Intel Corporation. All rights reserved.
Info: Your use of Intel Corporation's design tools, logic functions
Info: and other software and tools, and any partner logic
Info: functions, and any output files from any of the foregoing
Info: (including device programming or simulation files), and any
Info: associated documentation or information are expressly subject
Info: to the terms and conditions of the Intel Program License
Info: Subscription Agreement, the Intel Quartus Prime License Agreement,
Info: the Intel FPGA IP License Agreement, or other applicable license
Info: agreement, including, without limitation, that your use is for
Info: the sole purpose of programming logic devices manufactured by
Info: Intel and sold by Intel or its authorized distributors. Please
Info: refer to the applicable agreement for further details, at
Info: https://fpgasoftware.intel.com/eula.
Info: Processing started: Fri Sep 25 23:39:49 2020
Info: Command: quartus_eda --gen_testbench --tool=modelsim_oem --format=verilog --write_settings_files=off mux_2_1 -c mux_2_1 --vector_source=D:/report/Waveform.vwf --testbench_file=D:/report/simulation/qsim/Waveform.vwf.vt
Warning (18236): Number of processors has not been specified which may cause overloading on shared machines. Set the global assignment NUM_PARALLEL_PROCESSORS in your QSF to an appropriate value for best performance.
Completed successfully.
**** Generating the timing simulation netlist ****
quartus_eda --write_settings_files=off --simulation --functional=off --flatten_buses=off --timescale=1ps --tool=modelsim_oem --format=verilog --output_directory="D:/report/simulation/qsim/" mux_2_1 -c mux_2_1
Info: Processing started: Fri Sep 25 23:39:50 2020
Info: Command: quartus_eda --write_settings_files=off --simulation=on --functional=off --flatten_buses=off --timescale=1ps --tool=modelsim_oem --format=verilog --output_directory=D:/report/simulation/qsim/ mux_2_1 -c mux_2_1
Warning (10905): Generated the EDA functional simulation netlist because it is the only supported netlist type for this device.
Info (204019): Generated file mux_2_1.vo in folder "D:/report/simulation/qsim//" for EDA simulation tool
Info: Quartus Prime EDA Netlist Writer was successful. 0 errors, 2 warnings
Info: Peak virtual memory: 4742 megabytes
Info: Processing ended: Fri Sep 25 23:39:51 2020
Info: Elapsed time: 00:00:01
Info: Total CPU time (on all processors): 00:00:01
**** Generating the ModelSim .do script ****
D:/report/simulation/qsim/mux_2_1.do generated.
**** Running the ModelSim simulation ****
C:/intelFPGA_lite/20.1/modelsim_ase/win32aloem/vsim -c -do mux_2_1.do
Reading pref.tcl
# 2020.1
# do mux_2_1.do
# Model Technology ModelSim - Intel FPGA Edition vlog 2020.1 Compiler 2020.02 Feb 28 2020
# Start time: 23:39:52 on Sep 25,2020
# vlog -work work mux_2_1.vo
# -- Compiling module mux_2_1
# Top level modules:
# mux_2_1
# End time: 23:39:52 on Sep 25,2020, Elapsed time: 0:00:00
# Errors: 0, Warnings: 0
# vlog -work work Waveform.vwf.vt
# -- Compiling module mux_2_1_vlg_vec_tst
# mux_2_1_vlg_vec_tst
# Error loading design
Error: can't read "FileWatch(fileName)": no such element in array
Error.
I haven't seen this error before.
Do you able to simulate it before in a previous project or older Quartus version?
You can refer to the video reference attached on how to simulate using University Program VWF.
We do not receive any response from you to the previous question/reply/answer that I have provided. Please post a response in the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
Shyan Yew
