Hello all,
I am getting this error during compilation (partition merge).How to track this issue.Please suggest. Internal Error: Sub-system: CUT, File: /quartus/db/cut/cut_post_syn_util.cpp, Line: 709 name_to_atom_map[iname] == 0 Stack Trace: 0x31f82c: cut_sanity_check_atom_names + 0x36c (db_cut) 0x57c37: AMERGE_MERGER_OP::perform_post_merge_operations + 0xdf7 (atm_amerge) 0x48c7: amerge_combine_netlist + 0x2a7 (atm_amerge) 0x4a20: _amerge_start + 0x10 (atm_amerge) 0x331c9: qatm_merge_netlist + 0xe9 (quartus_cdb) 0x17ff2: qatm_import_database + 0xc22 (quartus_cdb) 0x1e4ce: QATM_FRAMEWORK::execute + 0x113e (quartus_cdb) 0xfbb1: qexe_get_tcl_sub_option + 0x1641 (comp_qexe) 0x1203b: qexe_process_cmdline_arguments + 0x3cb (comp_qexe) 0x12123: qexe_standard_main + 0x83 (comp_qexe) 0x1541a: qatm_main + 0x4a (quartus_cdb) 0x4c91: msg_main_thread + 0x11 (CCL_MSG) 0x1be8: _thr_final_wrapper + 0x8 (ccl_thr) 0x5375: msg_thread_wrapper + 0x85 (CCL_MSG) 0x37e7: mem_thread_wrapper + 0x47 (ccl_mem) 0x5fa1: msg_exe_main + 0x81 (CCL_MSG) 0x1a14c: _main + 0x1c (quartus_cdb) 0x375f4: __chkstk + 0x184 (quartus_cdb) 0x133c9: BaseThreadInitThunk + 0x11 (kernel32) 0x39ed1: RtlInitializeExceptionChain + 0x62 (ntdll) 0x39ea4: RtlInitializeExceptionChain + 0x35 (ntdll) End-trace Quartus II 32-bit Version 12.1 Build 177 11/07/2012 SJ Full VersionLink Copied
Hi, are you willing to submit your design to Engineering? If so, please send an archive of the design to cauduong@altera.com. Once we can access the issue, we can most likely provide a workaround.
Thanks, Cam
