Error in Assembler
Hi All,
I encounter assembler error in Quartus 9.0 SP2.
The error message is as following:
How to fix it?
Thank you. :)
Internal Error: Sub-system: ASM, File: /quartus/comp/asm/asm_lab.cpp, Line: 2560
num_matches == 1
Stack Trace:
0x230F66 : asm_assemble + 0x4DD6 (comp_asm)
0x23064C : asm_assemble + 0x44BC (comp_asm)
0x22F516 : asm_assemble + 0x3386 (comp_asm)
0x22C631 : asm_assemble + 0x4A1 (comp_asm)
0xCCFF : qexe_get_command_line + 0x26F (comp_qexe)
0x38E3 : QCU_ACF_SETTING::operator= + 0x11E3 (comp_qcu)
0x7C29 : QCU_FRAMEWORK::check_license + 0x139 (comp_qcu)
0xFBBD : qexe_process_cmdline_arguments + 0x34D (comp_qexe)
End-trace
Quartus II Version 9.0 Build 235 06/17/2009 SJ Full Version
Service Pack Installed: 2
