17255 Discussions
Error in Hello_world_small compilation !
I'm just trying to get nios II ide to work with a simple Hello_world_small application.
But I get a compilation error related to the "alt_putstr()" function...
The board is working without this function (ie. led counting etc..)
I leave all the setting to the defaults settings ...
Here, the first error :
/cygdrive/c/altera/81/nios2eds/components/altera_hal/HAL/src/alt_putstr.c undefined reference to `null'
Then the following 4 errors are related to this function...
Here the console output :
**** Build of configuration Release for project hello_world_small_1 **** make -s all includes Compiling hello_world_small.c... Linking hello_world_small_0.elf... /cygdrive/c/NiosII/software/hello_world_small_0_syslib/Release/libhello_world_small_0_syslib.a(alt_putstr.o)(.text+0x1c): In function `alt_putstr': /cygdrive/c/altera/81/nios2eds/components/altera_hal/HAL/src/alt_putstr.c:64: undefined reference to `null' /cygdrive/c/NiosII/software/hello_world_small_0_syslib/Release/libhello_world_small_0_syslib.a(alt_putstr.o)(.text+0x20):/cygdrive/c/altera/81/nios2eds/components/altera_hal/HAL/src/alt_putstr.c:64: undefined reference to `null' /cygdrive/c/NiosII/software/hello_world_small_0_syslib/Release/libhello_world_small_0_syslib.a(alt_putstr.o)(.text+0x28):/cygdrive/c/altera/81/nios2eds/components/altera_hal/HAL/src/alt_putstr.c:64: undefined reference to `ALT_MODULE_CLASS_null_write' /cygdrive/c/NiosII/software/hello_world_small_0_syslib/Release/libhello_world_small_0_syslib.a(alt_putstr.o)(.text+0x2c):/cygdrive/c/altera/81/nios2eds/components/altera_hal/HAL/src/alt_putstr.c:64: undefined reference to `ALT_MODULE_CLASS_null_write' collect2: ld returned 1 exit status make: *** Error 1 Build completed in 14.321 seconds
Please help me, what's wrong ?
i think you can turn off the lightweight device driver API to get around this.
Thank you very much for your fast reply..
But what is the lightweight driver ?
And where I can turn off this driver ?
Thanks...
in Nios IDE right click on your project hello_world_small0 and go down to System Library Properties. then uncheck the Lightweight device driver API box.
thepancake !! Thank you !
It was my problem !!
Now I don't have this problem !!!
But, I don't see anything in the console of the nios II IDE...
How can I get message in the console ?
Thank you again for your previous fast replies !!
make sure the stdout is set as jtag_uart in the same System Libraries window.
then run on your target hardware.
Man, you're the best !
Thank you for your fast reply !
I don't have the choice...
I have only the "null" choice in the stdout, even in the stdin and stderr etc..
What's wrong ?
Uhhh... I forgot to place the jtag_uart module in SOPC...
Now I have jtag_uart_0, which is appear...
But even it's selected, I don't have any echos in the console ?
Here : the output of the console
Using cable "USB-Blaster ", device 1, instance 0x00 Pausing target processor: OK Initializing CPU cache (if present) OK Downloading 00002000 ( 0%) Downloaded 3KB in 0.0s Verifying 00002000 ( 0%) Verified OK Leaving target processor paused
I made some reset (hard reset with a push button..) and I don't have anything else in the console output...
What's is wrong please ?
is the clock connected and are you sure the reset is of correct polarity, it should be active high. i am not sure whether NIOS IDE will download the program file if either the clock or reset is not connected correctly. you might check niosforum.com for similar issues.
Hi, i'm using Nios2 9.1 and i'm getting the same error...i cant find any system library properties...any way to solve it?
*Solved the problem by adding a JTAG_UART (stdout device) in SOPC
i use quartus 10.1,and i can't find what you say " uncheck the Lightweight device driver API box",eager for your answer
I too hit this issue. It is rather a shame that the HAL does not provide the trivial support required to have both Lightweight Drivers enabled *and* no stdin/stdout/stderr devices selected.
The solution is pretty trivial. Drop something like this into a .c file in your project:
struct ALT_MODULE_CLASS_null_state_s {void * dummy;} null;
int alt_module_class_null_write(struct ALT_MODULE_CLASS_null_state_s * sp, const char* ptr, int len, int flags)
return len;
I've had this issue on my board when I had switch for programm/run located in the wrong position.
