17252 Discussions
Error:invalid command name "quartus_sh"
I want to run some_script.tcl before compilation. To do it I set "set_global_assignment -name PRE_FLOW_SCRIPT_FILE quartus_sh:some_script.tcl" in tcl console.
But there is no effect from setting the assignment. Now I see that quartus_sh does not work at all:
quartus_sh
Error: while executing
Error:"unknown_original quartus_sh"
Error: ("eval" body line 1)
Error: invoked from within
Error:"eval unknown_original $cmd $args"
Error: (procedure "::unknown" line 7)
Error:"quartus_sh"
But there is no problems with running quartus_sh from command line. The path to the quartus_sh is added to PATH variable.
In internet the question is very popular, but as I see it was not solved.
What should I do to walk this problem around?
Where are you seeing that invalid command name error? When hitting compile and the pre_flow_script is run, or are you typing it into Quartus Tcl. It is not part of the Quartus Tcl console.
When you say there is no effect, what do you mean? I assume some_script.tcl exists in the project directory. When you compile, I believe there should be messages that it is running a script. Maybe add as the first line of your script something like:
post_message "some_script.tcl is running"
I'm attaching an example one I have lying around, although it's over ten years old, but I believe it should work.
