17266 Discussions
Error message when simulating - "delay annotation information"
I get the following error message when I try to simulate anything with Quartus:
Error: Can't continue simulation because delay annotation information for design is missing
I did edit "delay requirements" (under "assignments" -> "timing settings" ) after the error, and still get the same error.
Is there anywhere else I can put this information in?
Any ideas what I am missing?
I have 3 different "programs" / assignments that I am getting this same error message on.
Thanks for any advice!
--- Quote Start ---
--- Quote End ---
you have to run all processing step incl. the timing analysis. The missing delay information is extracted by the timing analyzer.
Kind regards
GPK
Ah-ha, thanks! I was not doing that.
So - another question - try to run the timing analysis, and get this:
Error: Can't run Timing Analyzer (quartus_tan) -- Fitter (quartus_fit) failed or was not run
What/where is the "fitter?" ???
Thanks again!
--- Quote Start ---
Thanks again!
--- Quote End ---
sorry my fault.
In order to run the timing analyzer you have to perform a complete run, which includes:
1. Analysis & Elaboration
Your HDL is analyzed , the Hierachy is extratcted etc.....
2. Synthesis
Your design is converted in Logic, Register ....
3. Mapping
Your design is mapped to FPGA resource like LUT's, DSP Blocks ....
4. Fitter
Your design is placed and routed
5. Timing Analysis
After Place&Route you can analysis the real timing of your design
That all you need to put your design in the FPGA.
Kind regards
GPK
