I do not understand why I am getting the error message for the code below....
Error (10818): Netlist error at up_dwn_counter.vhd(61): can't infer register for d_o[0] because it does not hold its value outside the clock edge Thank you in advance!! Bojan ************************* library ieee; use ieee.std_logic_1164.all; --use ieee.numeric_std.all; use ieee.std_logic_arith.all; use ieee.std_logic_unsigned.all; entity up_dwn_counter is port ( rst : in bit; clk : in bit; --uartclk : out bit; u_d, cl :in bit; d_o : out std_logic_vector (31 downto 0) ); end up_dwn_counter; architecture counter of up_dwn_counter is shared variable counter: std_logic_vector (31 downto 0);-- :="00000000000000000000000000000000"; begin count: process (cl, rst, u_d) begin if (rst'event and rst = '1') -- This is supposed to check for rising edge of rst then d_o <= "00000000000000000000000000000000"; counter:="00000000000000000000000000000000"; if (cl'event and cl = '1') -- This is supposed to check for rising edge of cl then if (u_d = '1') then counter := counter + "1"; else counter := counter - "1"; end if; else if (cl'event and cl = '0')-- This is supposed to check for falling edge of cl then if (u_d = '0') then counter := counter - '1'; else counter := counter + '1'; end if; end if; d_o <= counter; -- to_StdLogicVector(counter);-- (31 downto 0); end if; -- clockevent end if; -- rst_event end process; end; -- end of architecture "counter"Link Copied
You need to think about what hardware you want to generate. A register is only sensitive to 1 clock edge, either rising or falling so if you remove the section of code that checks for the falling edge of cl then you should be ok.
Always use the recommended coding style. See http://www.alteraforum.com/forum/showthread.php?p=3369#post3369 for a reference to the coding guidelines in the Quartus handbook.
Thanks guys, I will have a look at recommendations...
