I'm using the latest Quarts and AOCL combination (v15.0.1) on Linux (RHELv6). I have been observing an error with the aoc compiler when compiling HDL. aoc -c foo.cl works fine, but aoc foo.aoco results in an error saying: "Error: s0: Cannot find sequencer/sequencer.elf". A full compilation log is attached. This problem happens with different kernel files, but apparently it does not always so. Rebooting the system seems to have a positive effect, but not a 100% cure. I have searched through the forum logs and found some related messages, but not able to find actual solutions. I'd highly appreciate if anyone could help me solve the compilation problem.Link Copied
I have found that this happens when using certain X11. On my Mac it does this all the time so I just ssh without "-X". For some reason this does the trick. Let me know if this helps
Same thing happened to me a lot since version 14. I had to logout and log back into fix this. And I wasn't using X11, I was doing everything with screen in terminals.
I didn't use "-X", but now I can compile kernels successfully by logging into my development host with "ssh -x" (dash + lower-letter x)! I have no idea why X is related to the problem, but thanks so much, mhogains!
Oh so X11 forwarding is automatically enabled on your host? dash + lower x turns that off, if it's enabled. Interesting. I'm glad this helped.
That's actually something strange that I still don't understand since it should not be enabled by default. Perhaps, the problem disappeared because I simply logged off and in to the machine, and the ssh X forwarding may not be relevant. In fact, I observed the same problem again even with 'ssh -x', but again it is "fixed" with relogin. Anyway, now I seem to be able to work around the problem.
