I am trying to generate the SPI (4 Wire Serial) Intel FPGA IP core, but the platform designer fails to generate the HDL. It looks like it could be due to "Info: spi_0: Illegal division by zero at /tools/intelFPGA_lite/23.1std/quartus/../ip/altera/sopc_builder_ip/altera_avalon_spi/em_spi_qsys.pm line 330." Please advise. Thanks in advance.
Please don't export the clock and reset ports then connect those ports to the clock source.
regards,
Sheng
Are you trying to create just the IP to instantiate in your design or are you creating a Platform Designer system that includes this IP? If it's the former, you should be adding it to your Quartus project from the IP Catalog in Quartus itself, not in an empty Platform Designer system like you are showing here.
If you're trying to create a system design that includes the IP, I'm not sure if you're getting the error because the rest of the system is empty, which would be odd.
But better to understand what your use case is here first.
Thanks for your reply. My use case is actually just the former -- just looking to utilize the standalone IP. However, I have noticed multiple cores are only available in the IP catalog found through the Platform Designer, not the regular IP Catalog in Quartus. The SPI (4 Wire Serial) Intel FPGA IP core happens to be one of these. Attached is a screenshot of SPI results in the regular IP Catalog. Perhaps I am missing something?
What are you trying to connect to with this interface?
I am sending data from existing buffers in my design to an external MCU.
Could you double click the IP to see any error settings configuration?
If got error, it'll not be generated.
Sheng
Yes, no errors after configuration before generating HDL.
regards,
Sheng
That worked! Thank you. Why was the clock source needed in this case but not always using other IP cores in Platform Designer?
That SPI IP is always associated with other ip. So please generate it together with other IPs in .qsys system instead of standalone.
I see. To clarify, I was wondering why this IP requires a clock source, whereas others don't. What makes this one different? Thank you.
reopening the case
