17252 Discussions
Error using shift and power operator
Hi;
I am getting error using sla and ** operators.
My code is as under :
Rx_Buff_i : in STD_LOGIC_VECTOR (7 downto 0);
signal Chksum : std_logic_vector(7 downto 0) :=
(others => '0');
signal Shft_buff : std_logic_vector(1607 downto
0) :=(others => '0');
Shft_buff<= Shft_buff sla 8;
Chksum <= Chksum ** Rx_Buff_i;
I am including the following libraries:
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_unsigned.ALL;
use IEEE.std_logic_arith.all;
use IEEE.numeric_std.ALL;
The following errors I am getting
1)found '0' definitions of operator "sla", cannot
determine exact overloaded matching definition
for "sla"
2) found '0' definitions of operator "**", cannot
for "**"
plz help
--- Quote Start ---
Hi;
--- Quote End ---
Please, don't use numeric_std and std_logic_arith/unsigned at the same time! That makes for a lot of type confusion. Use numeric_std only.
--- Quote Start ---
for "sla"
--- Quote End ---
Regarding the sla operator, it is not defined for std_logic_vector. It is defined (in numeric_std) for unsigned and signed, but they're problematic and nobody uses them (and they may not synthesize). Instead, just use the usual shift left:
ShiftLeft : process (clk) is begin if rising_edge(clk) then foo <= foo(foo'left - 1 downto 0) & '0'; end if; end process ShiftLeft;
--- Quote Start ---
for "**"
plz help
--- Quote End ---
The exponent has to be:
a) a constant (compile-time) integer. It cannot be a variable and it certainly cannot be a std_logic_vector.
b) a power-of-two, which means it is implemented as a shift left.
So just use the shift left.
