17258 Discussions
Error: (vsim-3173) Entity '...' has no architecture.
AvramG
Hi.
I intend to work on Cyclone10 chip. I try to do a simulation on 1-port RAM IP in Questa.
When I run my compile_async_player.do file with the following commands:
vcom -stats=none -work work -2008 -explicit -vopt ./async_input_bram_player/async_input_bram_player_tb.vhd
set TOP_LEVEL_NAME async_input_bram_player_tb
set QSYS_SIMDIR ./async_input_bram_player/async_input_bram_player/sim
source $QSYS_SIMDIR/mentor/msim_setup.tcl
ld_debug
I get the error message:
# Loading work.async_input_bram_player_tb(testbench)#1
# ** Error: (vsim-3173) Entity 'C:/svn/exo_r_c10gx/simulation_bad/libraries/work.async_input_bram_player' has no architecture.
Attached are 2 zip files with 2 similar projects:
"simulation_bad"  - not working
"simulation_good"  - working
The difference between the 2 projects (bad and good) is the project path (of the compile_async_player.do file and libraries location).
I think the problem is the libraries folder, but I don't know how to change it.
thanks in advance.
ShengN_Intel
After I replace the simulation_bad file msim_setup.tcl script with the one in simulation_good file,  simulation_bad file can be simulated properly.
Sheng
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution and give Kudos.
AvramG
Hi Sheng,
Thanks for your help.
I replaced the msim_setup.tcl file and I got the same eror:
# ** Error: (vsim-3173) Entity 'C:/svn/exo_r_c10gx/Altera_community/simulation_bad/libraries/work.async_input_bram_player' has no architecture.
Could you upload your simulation_bad directory (after the fixing)?
I want to compare with mine.
Avram
ShengN_Intel
Any further update on this thread?
Sheng
ShengN_Intel
Hi Avram,
I didn't change anything in your simulation_bad file. I just simulate it with questa starter edition and then I got different error as below:
Fatal: (vsim-3693) The minimum time resolution limit (1ps) in the Verilog source is smaller than the one chosen for SystemC or VHDL units in the design. Use the vsim -t option to specify the desired resolution.
Then, I replace msim_setup.tcl in simulation_bad file with the one in simulation_good file and everything finally work fine.
Best Regards
Sheng
