17249 Discussions
Error: (vsim-3732) The following component port is not on the entity: # IR31_to_26
CPaul
Hello, I am trying to create a testbench for a mips processor in VHDL. It compiles fine in quartus and in modelsim but when I try to start the simulation I get this error.
* Error: (vsim-3732) D:/Quartus/4712labvhd/top_level.vhd(169): No default binding for component instance 'UUT_CON'.
#  The following component port is not on the entity:
#      IR31_to_26
Anything Helps. The first bit of code is the testbench itself and the next is the top level entity that I use inside.
library ieee; use ieee.std_logic_1164.all;   entity top_level is   generic( WIDTH : positive := 32 ); port ( clk : in std_logic; buttons : in std_logic_vector(1 downto 0); switches : in std_logic_vector(9 downto 0); led0 : out std_logic_vector(6 downto 0); led0_dp : out std_logic; led1 : out std_logic_vector(6 downto 0); led1_dp : out std_logic; led2 : out std_logic_vector(6 downto 0); led2_dp : out std_logic; led3 : out std_logic_vector(6 downto 0); led3_dp : out std_logic; led4 : out std_logic_vector(6 downto 0); led4_dp : out std_logic; led5 : out std_logic_vector(6 downto 0); led5_dp : out std_logic ); end top_level;   architecture STR of top_level is   signal ADDRESS : std_logic_vector(31 downto 0); signal ALUOp : std_logic_vector(5 downto 0) ; signal IR31_to_26: std_logic_vector(5 downto 0); signal alu_out, alu_out_hi, A_out, B_out, regfileout1, regfileout2, MemoryRegOut, WRdata_out, HI_out, LO_out: std_logic_vector(31 downto 0);   signal ALUSrcB, PCSource, ALU_LO_HI : std_logic_vector(1 downto 0); signal OPSelect: std_logic_vector(5 downto 0); signal PCWriteCond, PCWrite, IorD, MemRead, MemWrite, IRWrite, MemToReg, JumpAndLink, IsSigned, ALUSrcA, RegWrite, RegDst : std_logic; signal inport_en, reset_en:std_logic; signal OutPort_int:std_logic_vector(31 downto 0); signal switch_int: std_logic_vector(31 downto 0);   component controller is generic ( width : positive := 32); port ( clk : in std_logic := '0'; rst : in std_logic := '0'; PCWriteCond : out std_logic; PCWrite : out std_logic; IorD : out std_logic; MemRead : out std_logic; MemWrite : out std_logic; MemToReg : out std_logic; IRWrite : out std_logic; JumpAndLink : out std_logic; IsSigned : out std_logic; PCSource : out std_logic_vector(1 downto 0); ALUOp: out std_logic_vector(5 downto 0) ; IR31_to_26 : in std_logic_vector(5 downto 0) ; ALUSrcB : out std_logic_vector(1 downto 0); ALUSrcA : out std_logic; RegWrite : out std_logic; RegDst : out std_logic ); end component;       component datapath is generic ( width : positive := 32); port ( clk : in std_logic; rst : in std_logic; switches: in std_logic_vector(31 downto 0); buttons: in std_logic_vector(1 downto 0); PCWriteCond : in std_logic; PCWrite : in std_logic; IorD : in std_logic; MemRead : in std_logic; MemWrite : in std_logic; MemToReg : in std_logic; IRWrite : in std_logic; JumpAndLink : in std_logic; IsSigned : in std_logic; PCSource : in std_logic_vector(1 downto 0); ALUOp : in std_logic_vector(5 downto 0) ; IR31_to_26 : out std_logic_vector(5 downto 0) ; ALUSrcB : in std_logic_vector(1 downto 0); ALUSrcA : in std_logic; RegWrite : in std_logic; RegDst : in std_logic; OutPort : out std_logic_vector(31 downto 0) );   end component;   component decoder7seg is port ( input : in std_logic_vector(3 downto 0); output : out std_logic_vector(6 downto 0)); end component;     -- signals for top_level   signal input1 : std_logic_vector(8 downto 0); signal input2 : std_logic_vector(8 downto 0); signal output_internal : std_logic_vector(6 downto 0);   begin   inport_en <= not buttons(0);   reset_en <= not buttons(1);   switch_int <= "0000000000000000000000" & switches;   -- map adder output to two LEDs U_LED5 : decoder7seg port map ( input =>OutPort_int(23 downto 20), output => led5);   U_LED4 : decoder7seg port map ( input => OutPort_int(19 downto 16), output => led4);   -- all other LEDs should display 0 U_LED3 : decoder7seg port map ( input => OutPort_int(15 downto 12), output => led3);   U_LED2 : decoder7seg port map ( input => OutPort_int(11 downto 8), output => led2); U_LED1 : decoder7seg port map ( input => OutPort_int(7 downto 4), output => led1);   U_LED0 : decoder7seg port map ( input => OutPort_int(3 downto 0), output => led0);     UUT_CON : controller port map( clk => clk, rst =>reset_en, PCWriteCond => PCWriteCond, PCWrite => PCWrite, IorD => IorD, MemRead => MemRead, MemWrite => MemWrite, MemToReg => MemToReg, IRWrite => IRWrite, JumpAndLink => JumpAndLink, IsSigned => IsSigned, PCSource => PCSource, ALUOp => ALUOp, IR31_to_26 => IR31_to_26, ALUSrcB => ALUSrcB, ALUSrcA => ALUSrcA, RegWrite =>RegWrite, RegDst => RegDst ); UUT_DATA : datapath port map( clk => clk, rst =>reset_en, switches => switch_int, buttons => buttons, PCWriteCond => PCWriteCond, PCWrite => PCWrite, IorD => IorD, MemRead => MemRead, MemWrite => MemWrite, MemToReg => MemToReg, IRWrite => IRWrite, JumpAndLink => JumpAndLink, IsSigned => IsSigned, PCSource => PCSource, ALUOp => ALUOp, IR31_to_26 => IR31_to_26, ALUSrcB => ALUSrcB, ALUSrcA => ALUSrcA, RegWrite =>RegWrite, RegDst => RegDst, OutPort => OutPort_int ); end STR;
library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_arith.all; use ieee.std_logic_unsigned.all; use ieee.numeric_std.all;   entity mips_tb is end mips_tb;   architecture TB of mips_tb is   component top_level is generic( WIDTH : positive := 32 ); port ( clk : in std_logic; buttons : in std_logic_vector(1 downto 0); switches : in std_logic_vector(9 downto 0); led0 : out std_logic_vector(6 downto 0); led0_dp : out std_logic; led1 : out std_logic_vector(6 downto 0); led1_dp : out std_logic; led2 : out std_logic_vector(6 downto 0); led2_dp : out std_logic; led3 : out std_logic_vector(6 downto 0); led3_dp : out std_logic; led4 : out std_logic_vector(6 downto 0); led4_dp : out std_logic; led5 : out std_logic_vector(6 downto 0); led5_dp : out std_logic );   end component;     signal output_PC : std_logic_vector(31 downto 0) := (others => '0'); signal clock_int : std_logic:='0'; signal data_int : std_logic_vector (31 downto 0); signal wren_int : std_logic ; signal q_int : std_logic_vector (31 downto 0); signal reset_int :std_logic; signal mux_sel : std_logic_vector(1 downto 0); signal buttons_int : std_logic_vector(1 downto 0); signal switches_int : std_logic_vector(9 downto 0);     begin   UUT_top : top_level port map( clk => clock_int, buttons => buttons_int, switches => switches_int );   clock_int <= not clock_int after 10 ns; process begin     reset_int <='1';   wait for 50 ns;   reset_int <='0';   wait for 50 ns;     end process; end TB;
AnandRaj_S_Intel
Hi @CPaul​
Can you attach complete project. So that we can simulate in our side once and check.
Anand
CPaul
@Anand​
Here is the QAR file. I am a beginner VHDL coder so please bear with me if I am confused by simple concepts.
AnandRaj_S_Intel
Hi @CPaul​ ,
I can simulate your design without any error
Compile all the vhd files again in proper order try.
attached transcript from which you can find the information on error which i have faced because of compile order and image.
Let me know if this has helped resolve the issue you are facing or if you need any further assistance.
CPaul
@Anand​
I am a bit confused on how to actually read the transcript for what the compile order of my files should be. is it possible you could tell me what files you included in the compilation and what order they were in on modelsim?
AnandRaj_S_Intel
Hi @CPaul​ ,
Order "decoder7seg.vhd" "memory.vhd" "mux2x1.vhd" "mux2x1_5bit.vhd" "mux4x1.vhd" "ram_256.vhd" "reg32.vhd" "register_file.vhd" "sign_extend.vhd" "alu_control.vhd" "alu_ns1.vhd" "controller.vhd""datapath.vhd"  which worked. copy past it in file name under compile source file tab.
For error which you have you have to compile controller .vhd and run simulation.
Anand
CPaul
@Anand​
I got the simulation to run. However I am getting many undefined values and my clock is not clocking. Is this the same results you got?
AnandRaj_S_Intel
​Hi @CPaul,
Yes, I was able to see the clock running.
  1. Uninitialized out port has no driver check your design and its mapping.
  2. place week2_demo.mif in simulation directory.
Anand
