17261 Discussions
Error while running the program in cyclone II board
Hi Everyone,
I am a beginner in design.
I designed a hardware using Quartus 2 and downloaded the design to the board.
Also I tried running the hello world program from the NIOS 2 IDE 9.1, but it threw error like the one below.
Using cable "USB-Blaster [USB-0]", device 1, instance 0x00
Pausing target processor: not responding.
Resetting and trying again: FAILED
Leaving target processor paused
Please someone help me out
please do not multipost your questions
--- Quote Start ---
--- Quote End ---
This usually happens when you are using a time limited OpenCorePlus IP (in this case NIOS 2).
After you configure fpga with usb blaster, don't close the message box, otherwise the usb programmer will disconnect and the ip core will be disabled.
Cris
