Error
I vonder what is wrong in this code:
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
use ieee.std_logic_unsigned.ALL;
entity uppgift_vhdl_3a is
port
( Sys_clk, reset_n, knapp_in_1 : in std_logic;
lysdiod_ut : out std_logic_vector(2 downto 0)
End entity uppgift_vhdl_3a;
architecture rtl of uppgift_3a_debugg is
---- internal signal declaration
signal signal_raknarvarde : std_logic_vector(2 downto 0);
signal old_knapp_in_1 :std_logic;
begin
process (sys_clk)
begin
if (rising_edge(sys_clk)) then
if reset_n = '0' then ---Reset the counter to 0
23 signal_raknarvärde <= "000";
25 elsif knapp_in_1 = '1'; then
signal_raknarvarde <= signal_raknarvarde + '1';
else
signal_raknarvarde <= signal_raknarvarde;
end if;
end if;
end process;
36
:cry:....?
Error come up..
Error (10500): VHDL syntax error at uppgift_3a.vhd(23) near text ¤
Error (10500): VHDL syntax error at uppgift_3a.vhd(23) near text "¤"; expecting "(", or "'", or "."
Error (10500): VHDL syntax error at uppgift_3a.vhd(25) near text ";"; expecting "then"
Error (10522): VHDL Syntax error at uppgift_3a.vhd(36): experienced unexpected end-of-file ; expecting "end", or "(", or an identifier, or a concurrent statement
Not sure about line 23, try renaming your signal name without the "ä" and use "a" instead. (note the accent marks)
line 25 should not have the ';' character between "if" and "then".
Fixing both of these might clear up your problems.
--- Quote Start ---
--- Quote End ---
Thanks :rolleyes:. Do you know what this is ?
Ahh, didn't notice what you were missing - add
end rtl;
at the end. You need to close out your architecture.
