17267 Discussions
Errors linking Modelsim BFM models
I am trying to run a Verilog simulation of a test bench generated by Qsys 14.0 of a system that includes an ARM SoC HPS block.
The originally generated test bench from ip-make-simscript --spd=...../soc_system_tb.spd
did not include what I believe is a required element on the sim command line =
-mvchome $QUARTUS_ROOTDIR/../ip/altera/mentor_vip_ae/common +define+MODEL_TECH
After point that to the Altera mentor_vip_ae/common dir I then get the following errors from vsim.
I am using the latest Questa 10.3c
Any suggestions?
Thanks Martin
Loading fpga_interfaces.mgc_common_axi_sv_unit(fast)# Loading fpga_interfaces.mgc_common_axi(fast__3)# ** Error: (vsim-8388) Could not find the MVC shared library : MvcHome directory '/net/tcfiler2.scs.agilent.com/vol/v51/rpdhw/tools/altera/14.0//../ip/altera/mentor_vip_ae/common' is not a valid MVC installation for an available linux_x86_64 GCC version in /net/tcfiler2.scs.agilent.com/vol/v51/rpdhw/tools/mentor/modeltech/10.3c/questasim (available versions: 4.3.3 4.5.0 ). Please check MvcHome setting in modelsim.ini or on command line (-mvchome).# Loading fpga_interfaces.mgc_common_axi(fast__4)# ** Error: (vsim-8388) Could not find the MVC shared library : MvcHome directory '/net/tcfiler2.scs.agilent.com/vol/v51/rpdhw/tools/altera/14.0//../ip/altera/mentor_vip_ae/common' is not a valid MVC installation for an available linux_x86_64 GCC version in /net/tcfiler2.scs.agilent.com/vol/v51/rpdhw/tools/mentor/modeltech/10.3c/questasim (available versions: 4.3.3 4.5.0 ). Please check MvcHome setting in modelsim.ini or on command line (-mvchome).# Loading fpga_interfaces.altera_avalon_interrupt_sink(fast)# Loading fpga_interfaces.mgc_common_axi(fast__5)# ** Error: (vsim-8388) Could not find the MVC shared library : MvcHome directory '/net/tcfiler2.scs.agilent.com/vol/v51/rpdhw/tools/altera/14.0//../ip/altera/mentor_vip_ae/common' is not a valid MVC installation for an available linux_x86_64 GCC version in /net/tcfiler2.scs.agilent.com/vol/v51/rpdhw/tools/mentor/modeltech/10.3c/questasim (available versions: 4.3.3 4.5.0 ). Please check MvcHome setting in modelsim.ini or on command line (-mvchome).# Loading arriav_ver.arriav_hps_interface_fpga2sdram(fast)# Loading fpga_interfaces.altera_avalon_clock_source(fast)
SO I fixed the link to find the MVC library.
But now I get many errors like this one:
# Loading /net/tcfiler2.scs.agilent.com/vol/v51/rpdhw/tools/altera/14.0/quartus/../ip/altera/mentor_vip_ae/common/questa_mvc_core/linux_x86_64_gcc-4.5.0/libaxi_IN_SystemVerilog_MTI_full.so
# ** Error: (vsim-3197) Load of "/net/tcfiler2.scs.agilent.com/vol/v51/rpdhw/tools/altera/14.0/quartus/../ip/altera/mentor_vip_ae/common/questa_mvc_core/linux_x86_64_gcc-4.5.0/libaxi_IN_SystemVerilog_MTI_full.so" failed: libaxi_IN_SystemVerilog_MTI.so: cannot open shared object file: No such file or directory.
Martin
--- Quote Start ---
# Loading /net/tcfiler2.scs.agilent.com/vol/v51/rpdhw/tools/altera/14.0/quartus/../ip/altera/mentor_vip_ae/common/questa_mvc_core/linux_x86_64_gcc-4.5.0/libaxi_IN_SystemVerilog_MTI_full.so# ** Error: (vsim-3197) Load of "/net/tcfiler2.scs.agilent.com/vol/v51/rpdhw/tools/altera/14.0/quartus/../ip/altera/mentor_vip_ae/common/questa_mvc_core/linux_x86_64_gcc-4.5.0/libaxi_IN_SystemVerilog_MTI_full.so" failed: libaxi_IN_SystemVerilog_MTI.so: cannot open shared object file: No such file or directory.
Martin
--- Quote End ---
I am facing same issues i.e. getting errors related to mvchome.
How were you able to fix the errors?
Kind Regards,
Kamran Babar
The “Bad library format” errors usually occur if the simulation libraries were compiled with a different simulator version other than version you are running now.
Try remove the entire compiled database and recompile with your Questa 10.3c.
