17268 Discussions
USB Blaster JTAG chain broken
I'm using Ubuntu14.04 and quartus14.1. When I run jtagconfig, I get
$ jtagconfig
1) USB-Blaster [3-6]
Unable to read device chain - JTAG chain broken
The hardware is correct because I can read the JTAG chain using a old PC.
Some extra information:
$ cat /etc/udev/rules.d/51-usbblaster.rules# USB-Blaster
# # from http://www.fpga-dev.com/altera-usb-blaster-with-ubuntu/
# For Altera USB-Blaster permissions.
SUBSYSTEM=="usb",
ENV{DEVTYPE}=="usb_device",
ATTR{idVendor}=="09fb",
ATTR{idProduct}=="6001",
MODE="0666",
NAME="bus/usb/$env{BUSNUM}/$env{DEVNUM}",
RUN+="/bin/chmod 0666 %c"
$ ls -l /etc/jtagd/pgm_parts.txt
-rw-r--r-- 1 root root 921110 Jan 12 12:54 /etc/jtagd/pgm_parts.txt
I have also re-run:
$ sudo udevadm control --reload
But nothing help!
Any tips?
Same configuration as yours. Probably same reason: http://askubuntu.com/questions/288821/how-do-i-resolve-a-cannot-open-shared-object-file-libudev-so-0-error
--- Quote Start ---
$ jtagconfig
SUBSYSTEM=="usb",
MODE="0666",
I have also re-run:
But nothing help!
Any tips?
--- Quote End ---
Try do a "killall jtagd" see if it allowa jtagconfig to discover the on board chain.
