17259 Discussions
Expecting IDENTIFIER in Signals
Hey all,
I've googled this problem and it always seems to be a missing semicolon or paren somewhere, but I've looked over my code and I see nothing. I know it's going to be simple and I will feel stupid, but I am just learning VHDL and going by the book. What is wrong with my signal declaration here?
library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_unsigned.all; use ieee.numeric_std.all; -- Processor -- Mainly based off of Ch 4 in the CArch book entity jaggy is port (CLK, pwr, instrin: in std_logic); end jaggy; architecture struct of jaggy is -- Signals to interconnect components signal( d1, d2, d3, d4, d5, t1 : std_logic; a1 : std_logic_vector(7 downto 0); i1 : std_logic_vector(31 downto 0) ); begin -- Entities will be instantiated here -- Program Counter pc: entity work.prog_count port map(addrin => i1, addrout => a1); -- Instruction Memory im: entity work.instr_mem port map(PC => a1, instr => i1); -- Register File reg: entity work.reg_file port map(instrin => i1, dataout1 => d1, dataout2 => d2, memout => d3, datain1 => d4, datain2 => d5); -- ALU alu: entity work.arith_log_unit port map(datain1 => d1, datain2 => d2, dataout => d4); -- Data Memory dm: entity work.data_mem port map(addrin => d4, datain => d3, dataout => d5); -- Control Unit cu: entity work.contr_unit port map(t1); end struct;
** Error: D:/jaggy.vhd(14): near "(": (vcom-1576) expecting IDENTIFIER.
The error is because of the signal declaration.
Provide individual signal declaration like,
signal d1, d2, d3, d4, d5, t1 : std_logic; signal a1 : std_logic_vector(7 downto 0); signal i1 : std_logic_vector(31 downto 0);
Best Regards
Vikas Jathar
Intel Customer Support – Engineering
(Under Contract to Intel)
