17241 Discussions
Expression has 32 elements ; expected 16
Hi evryone !
Plz help I have some problems in my modul, i get errors in : Line 71: Expression has 32 elements ; expected 16
Line 47: Expression has 9 elements ; expected 16
The tow lines :
line 47 : wr <= curr_depth_bufbuf;
line 71 : shift_p <= 2*shift_p;
The declarations of generic and ports are the following with the signals also :
generic (
MAX_DEPTH : integer := 9; -- max tree depth
HASH_LENGTH : integer := 2; -- hash length in words
BLOCK_LENGTH : integer := 32; -- block length in words
MEM_WIDTH : integer := 16); -- word width
port (
clk : in std_logic;
rstb : in std_logic; -- active low async reset
start : in std_logic; -- start bit
path_depth : in std_logic_vector(MAX_DEPTH-1 downto 0); -- one hot
w_beta : in std_logic_vector(MAX_DEPTH-1 downto 0); -- selected node;
ptr : out std_logic_vector(MEM_WIDTH-1 downto 0); -- pointer value
wr : out std_logic_vector(MEM_WIDTH-1 downto 0); -- enable ptr writre
status : out std_logic); -- finish bit
signal curr_depth, curr_depth_buf, curr_depth_bufbuf : std_logic_vector(MAX_DEPTH-1 downto 0);
signal leftright, leftright_buf, status_tmp, leaf : std_logic; -- 1 is goto branch 1
signal shift_w, shift_p, w_addr, p_addr : unsigned(MEM_WIDTH-1 downto 0);
constant root_addr : integer := 2**MAX_DEPTH;
Thank you
curr_depth_bufbuf has width 9, but wr has width 16.
Simalarly for the other line
you need to set the generics correctly or change the code so the widths match.
Thank you for your reply
The other line is the same signal is a register that I multiply by 2
shift_p <= 2*shift_p; error --> Expression has 32 elements ; expected 16
His type is unsigned like you see !
Presumed you are using numeric_std library, the both errors can be fixed by writing:
shift_p <= shift_left(shift_p,1); -- or shift_p <= resize(2*shift_left,MEM_WIDTH); wr <= resize(curr_depth_bufbuf, MEM_WIDTH);
In the first case, you have the problem, that the bit width of unsigned multiply increases the bit width. Resize cuts the additional bits on the left, necessary to assign the result to signal with fixed bit width.
Similarly curr_depth_bufbuf must be zero filled on the left, resize can also do it. There are many other ways to achieve the same.
Yes, i am using numeric_std library
Knowing that resize return UNSIGNED in the case of an unsigned argument
After changing the code, I get this mistakes
47: Expecting type std_logic_vector for <resize>.
71: Formal <arg> has no actual or default value.
http://www.alteraforum.com/forum/attachment.php?attachmentid=13168&stc=1
You will find enclosed my code file
I have fixed these errors by passing from vector to unsigned but :(
Here my process :
Plz can you clarify me more about this process
-- purpose: Compute shifts
shift_proc: process (clk, start) is
begin -- process
if start = '0' then
shift_p <= (others => '1');
shift_w <= (others => '0');
p_addr <= to_unsigned(root_addr, 16) + to_unsigned(hash_length, 16);
elsif clk'event and clk = '1' then -- rising clock edge
if leftright = leftright_buf then
shift_p <= resize(2*shift_left, MEM_WIDTH);
shift_w <= shift_w + shift_p;
else
shift_w <= resize(2*shift_left, MEM_WIDTH);
shift_p <= shift_w + shift_p;
end if;
p_addr <= p_addr - shift_p*hash_length;
if leaf='0' then
w_addr <= p_addr - shift_w*hash_length;
else
w_addr <= p_addr - (unsigned(w_beta)/2)*hash_length - (shift_w-(unsigned(w_beta)/2))*block_length;
end if;
end if;
end process;
--- Quote Start ---
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
--use ieee.std_logic_unsigned.all;
entity witness is
generic (
port (
clk : in std_logic;
end entity witness;
architecture arch of witness is
signal curr_depth, curr_depth_buf, curr_depth_bufbuf : unsigned(MAX_DEPTH-1 downto 0);
constant root_addr : integer := 2**(MAX_DEPTH)-1;
begin -- architecture arch
-- purpose: Buffer some signals
buf: process (clk, rstb) is
begin -- process buf
curr_depth_bufbuf <= curr_depth_buf;
curr_depth_buf <= curr_depth;
leftright_buf <= leftright;
end if;
end process buf;
leftright <= '0' when (unsigned(w_beta) and curr_depth) = (9 downto 0 => '0') else '1'; --bitwise
leaf <= path_depth(MAX_DEPTH-1) and curr_depth_buf(0);
ptr <= std_logic_vector(w_addr);
wr <= std_logic_vector(resize(curr_depth_bufbuf, MEM_WIDTH));
-- purpose: shift current depth
-- type : sequential
shift_depth: process (clk, rstb) is
begin -- process shift_depth
if start = '0' then
curr_depth <= unsigned(path_depth);
else
curr_depth <= '0' & curr_depth(MAX_DEPTH-1 downto 1); --which level we are in the tree
end if;
end if;
end process shift_depth;
begin -- process
if start = '0' then
else
end if;
if leaf='0' then
else
end if;
end if;
end process;
-- purpose: Handle status bit
status_proc: process (clk, rstb) is
begin -- process status_proc
if rstb = '0' then -- asynchronous reset (active low)
status_tmp <= '0';
status_tmp <= status_tmp or curr_depth_bufbuf(0);
end if;
end process status_proc;
status <= status_tmp;
end architecture arch;
--- Quote End ---
here is my code can plz clarify me more about the process "compute shift"
What exactly do you need clarifying?
For example, for this registres.
what does it mean when we do this In terms of movement of bit :
shift_p <= 2*shift_left; or shift_w <= shift_w + shift_p;
this also
multiplying a number by 2^N shifts a number to the left by N bits.
The second line is just a normal subtract.
thank you, but i still not understand all the process, I will make a test bench and return to you :)
