17267 Discussions
FIR filter in Quartus
I am using the FIR compiler v8.0 in Quartus to design a lowpass FIR filter, the .vhd VHDL file and other files are generated by the tool, but I get an "unknown error" with the .bsf Block Symbol File, and this file isn't generated, anyone come across this type of error?
cheers,
Jamie
creat it by youself
as tangguoge said, a FIR filter is one of the simplest blocks in DSP Hardware and relatively simple to implement.
this could help you
http://www.alteraforum.com/forum/att...4&d=1223295458
and this
https://www.alteraforum.com/forum/attachment.php?attachmentid=741
can you send me the code?i will check it and tell you..
right clicking on the VHDL file and choosing Create Symbol Files for Current File will make a bsf for you.
