FPGA resources usage
Hi, after I compile my opencl code, the resources usage as flows:
; Estimated Resource Usage Summary ;
; Resource + Usage ;
; Logic utilization ; 139% ;
; ALUTs ; 59% ;
; Dedicated logic registers ; 81% ;
; Memory blocks ; 210% ;
; DSP blocks ; 73% ;
The FPGA is Arria 10. I want to know what's the relationship between 'Logic utilization' and 'ALUTs'. Why 'ALUTs' is 59% but 'Logic utilization' is 139%?
--- Quote Start ---
Here is Altera's interpretation:
https://www.altera.com/support/support-resources/knowledge-base/solutions/rd05172012_146.html
--- Quote End ---
Hi, thanks fot your reply! Should I use either "Logic utilization" or "ALUTs" to estimate resources usage? Thank you!
Logic utilisation is the more important. as you can see, as logic usage is > 100%, it will not fit in the device. (you also have 210% ram usage, so no chance)
--- Quote Start ---
--- Quote End ---
Thanks for your reply!
