17268 Discussions
Confusion about data type alignment
I need to transfer 128 structures from host to FPGA. In the host code,I define the structure as following:
*********************************************************************# define AOCL_ALIGNMENT 64
typedef struct
double S;
double X;
double u;
double e_rt_p;
double e_rt_q;
int CP;
}struct_A;
struct_A* input_A;
input_A=(struct_A *)_aligned_malloc(128*sizeof(struct_A),AOCL_ALIGNMENT);
in the kernel code,I define the structure as following:
typedef struct __attribute__((packed)) __attribute__((aligned(64)))
double S;
double X;
double u;
double e_rt_p;
double e_rt_q;
int CP;
}struct_A;
__kernel void kernels(__global double* restrict output_data, __global struct_A* restrict input_data)
for (int i=0;i<128;i++){
S = input_data.S;
X = input_data.X;
u = input_data.u;
e_rt_p = input_data.e_rt_p;
e_rt_q = input_data.e_rt_q;
CP = input_data.CP;
BUT, I can't get the values of S~cp in right order, when I remove "__attribute__((packed)) __attribute__((aligned(64)))", I can get the right values of S~cp
Can anyone figure out what's the problem in my code?Thanks very much.
