17267 Discussions
Fail to start Eclipse(DS-5) by using embedded command shell
Hi, guys,now I facing a problem which is cant launch DS-5 from the Embedded Command Shell .
After i type eclipse and enter under embedded command shell, it showed " bash:eclipse:command not found "
Anyone here had experienced on it and can provide solution to solved it?
Quartus13.0sp1 was used here.
thanks!
Another problem i faced is cant to make the executable file by using Embedded_Shell_Command ...It show " make:arm-linux-gnueabihf-gcc command not found"
Anyone here had faced it before and know how to solved this problem? Need Help !!!
