17268 Discussions
Failure for initialization ROM memory by using $readmemh task
Kun_Digital_Design
I initialized my ROM memory (instr_mem) by using the $readmemh task. The ROM was successfully complied and simulated, but the waveform show 32'hxxxxxxxx in instr_mem. It seems the 'instr_mem' didn't get the value from  mem_instruction.txt file.
module mips_mem(addr1,data_in1,data_out1,we1,
		addr2,data_in2,data_out2,we2,
		rst_b,clk);
   // Boundaries and lengths of each segment
   // Note that '_top' addresses off by one; the actual top is one less
   //      than the values below.
   // '_w' values are word addresses
   input         rst_b;
   input         clk;
   // Inputs and ouptuts: Port 1
   input [5:0]  addr1;         // Memory address
   input [31:0]  data_in1;      // Memory write data
   output [31:0] data_out1;     // Memory read data
   reg [31:0] 	 data_out1;
   input [0:3] 	 we1;           // Write enable (active high; 1 bit per byte)
   // Inputs and outputs: Port 2
   input [5:0]  addr2;         // Memory address
   input [31:0]  data_in2;      // Memory write data
   output [31:0] data_out2;     // Memory read data
   reg [31:0] 	 data_out2;
   input [0:3]	 we2;           // Write enable (active high; 1 bit per byte)
   o
   // Memory segments
   reg [31:0] 	 data_mem[0:63];
   reg [31:0] 	 instr_mem[0:63];
   // Verilog implementation stuff
   integer 	 i;
   wire [31:0] write_mask1 = {we1[3], we1[3], we1[3], we1[3],
			      we1[2], we1[2], we1[2], we1[2],
			      we1[1], we1[1], we1[1], we1[1],
			      we1[0], we1[0], we1[0], we1[0],
			      we1[0], we1[0], we1[0], we1[0]};
   // Handle Port 1 Read
   initial
	begin
		$readmemh("mem_instruction.txt", instr_mem);
	end
   always @(posedge clk or negedge rst_b) begin
	    if(rst_b==1'b0) begin
		     data_out1 <= 32'hxxxxxxxx;
		 end
		 else begin
		     data_out1 <=instr_mem[addr1];
		 end
	end
endmodule
ak6dn
Valued Contributor III
You need to provide a lot more context.
What version of Quartus?
What simulator and version?
Show the contents (at least some lines, not all) of your memory init file.
In your waveform display, can you add other signals like addr1[5:0]?
BTW you can collapse the data bit display, no need to show individual bits.
Kun_Digital_Design
Quartus Prime # Version 20.1.1
mem_Instruction.txt
2402000a
24080005
2509012c
240a01f4
254b0022
256b002d
0000000c
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
 The screenshot of waveform of addr1[5:0] signal
Kun_Digital_Design
I did the RTL simulation.
Kun_Digital_Design
I printed out the content of mem_instr by using $display. The mem_instruction.txt seems successfully included in the design.
Kun_Digital_Design
What version of Quartus? Quartus Prime # Version 20.1.1
2402000a
24080005
2509012c
240a01f4
254b0022
256b002d
0000000c
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000
RichardTanSY_Altera
Could you share the design .qar files and testbench so I can try to duplicate the issue from my side?
Kun_Digital_Design
The mips_mem is the part of the MIPS processor design. The testbench was used to test hold processor,
// Top module for the MIPS processor core
// NOT synthesizable Verilog!
`timescale 1ns/100ps
module testbench;
   reg [31:0] i;
   reg [29:0] addr;
   reg 	       rst_b;
   wire halted;
   //parameter
   parameter start = 0, halfPeriod = 50;
   reg 	     clk;
   // The clock
   initial
     clk = start;
   always
     #halfPeriod clk = ~clk;
   // The mips_top core
   mips_top inst_mips(.clk(clk), .rst_b(rst_b), .halted(halted));
   initial
     begin
	rst_b = 0;
	#75;
	rst_b <= 1;
     end
   always @(halted)
     begin
	#0;
	if(halted === 1'b1)
	  $finish;
     end
endmodule
Hi, I attached the design .qar file to this post.
RichardTanSY_Altera
I am checking on your design. Will let you know if any finding.
RichardTanSY_Altera
The $readmemh does work with Quartus. I suspecting design coding style.
Could you try to integrate the Quartus ROM template in your design?
Right click on any design file -> Insert template -> Verilog/VHDL -> RAMs and ROMs -> Dual Port ROM.
Kun_Digital_Design
I have integrated a Quartus dual port ram template in my design. It still doesn't work. I used the RTL simulation to generate the waveform. The waveform of ram instantiation still shows 32'bxxxxxxxxxxxxxxxx.
RichardTanSY_Altera
Any update/progress in this case? Do you need further help?
RichardTanSY_Altera
As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
Thank you.
Richard Tan
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 9/10 survey.
