17255 Discussions
Fitter setting: "Advanced Physical Optimization" leads to segmentation fault https://paste.ubuntu.com/p/RYFDDsw2qQ/
pprom
When I turned on the "Advanced Physical Optimization" within the fitter setting, I have the following error:
Problem Details Error:   *** Fatal Error: Segment Violation at (nil) Module: quartus_fit Stack Trace: 0x742a3: LBLK_ALE_STATE::initialize(DEV_FAMILY_ENUM, DEV_DEVICE_ENUM) + 0x13 (legality_lblk) 0x7d7c6: LBLK_LAB_STATE::initialize() + 0x56 (legality_lblk) 0x89bf80: LLC_INTERFACE::getDefaultOpts() + 0x70 (fitter_vpr20kmain) 0x8b9888: LLC_INTERFACE::legalizeWithLLC(APL_INTERFACE*, LBLK_LAB&, std::vector<APL_NODE const*, tbb::scalable_allocator<APL_NODE const*> > const&, bool, bool) + 0x68 (fitter_vpr20kmain) 0x8ba0fd: PCL::APL::LegalityChecker::legalize(std::vector<APL_NODE const*, tbb::scalable_allocator<APL_NODE const*> > const&, PCL::LLC::Checker<APL_NODE, PCL::APL::LegalLabState>::LEGALIZATION_LEVEL, PCL::APL::LegalLabState**) const + 0xed (fitter_vpr20kmain) 0x8ba757: PCL::APL::APLHandler::createCoresFromNetlist(PCL::APL::APLHandler::LSCBCRun*, PCL::APL::APLHandler::BFCRun*, APL_NODE const*, unsigned long, PCL::LSC::ClusterGraph<APL_NODE, PCL::APL::LegalLabState, PCL::CLUSTER::Cluster<APL_NODE, PCL::APL::LegalLabState> >*, bool) + 0x2d7 (fitter_vpr20kmain) 0x8c740f: PCL::APL::APLHandler::createGraphFromAPLNode(PCL::APL::APLHandler::LSCBCRun*, APL_NODE const*, APL_DISTRIBUTION<APL_NODE const*> const&, PCL::APL::LegalityChecker*, PCL::APL::APLHandler::PCLRunProperties*) + 0x8f (fitter_vpr20kmain) 0x8cc37c: PCL::APL::APLHandler::setPCLRun(unsigned long, PCL::APL::APLHandler::LSCRun const*) + 0xd9c (fitter_vpr20kmain) 0x8cd397: PCL::APL::APLHandler::cluster() + 0xb7 (fitter_vpr20kmain) 0x8cde28: APL::cluster() + 0x88 (fitter_vpr20kmain) 0x84aa91: do_analytical_placement + 0x1411 (fitter_vpr20kmain) 0x84bfc2: do_analytical_placement_phase + 0x2a2 (fitter_vpr20kmain) 0x828348: do_clustering + 0x838 (fitter_vpr20kmain) 0x82a799: cl_flow_pack_to_cbes + 0x2a9 (fitter_vpr20kmain) 0x82aefa: l_do_clustering_phase + 0xda (fitter_vpr20kmain) 0x83546d: aa_flow_place + 0x1d (fitter_vpr20kmain) 0x835dfe: aa_flow_fit + 0x4e (fitter_vpr20kmain) 0x6e2c64: VPR_QI_FACADE::vpr_qi_main() + 0x24 (fitter_vpr20kmain) 0x6853e: fitapi_run_vpr + 0x5e (fitter_fitapi) 0xba65a: FITCC_EXPERT::run_vpr() const + 0xba (fitter_fitcc) 0xbb2ca: FITCC_EXPERT::place_and_route() const + 0xba (fitter_fitcc) 0xbda00: FITCC_EXPERT::invoke_fitter() const + 0xea0 (fitter_fitcc) 0x161ee: ftitan_execute + 0x1f2 (fitter_ftitan) 0x2457e: fmain_start(CMP_FACADE*) + 0x4ae (fitter_fmain) 0x1f826: qfit_execute_fit(QCU_FRAMEWORK*, QFIT_FRAMEWORK*) + 0x1d6 (comp_qfit_legacy_flow) 0x1bda2: QFIT_FRAMEWORK::execute() + 0x282 (comp_qfit_legacy_flow) 0x23568: qfit_legacy_flow_run_legacy_fitter_flow + 0x218 (comp_qfit_legacy_flow) 0x4d671: TclInvokeStringCommand + 0x81 (tcl8.6) 0x51ec7: TclNRRunCallbacks + 0x47 (tcl8.6) 0x536e7: TclEvalEx + 0x947 (tcl8.6) 0xfb366: Tcl_FSEvalFileEx + 0x266 (tcl8.6) 0xfb47e: Tcl_EvalFile + 0x2e (tcl8.6) 0x11ebc: qexe_evaluate_tcl_script(std::string const&) + 0x382 (comp_qexe) 0x18dcf: qexe_do_tcl(QEXE_FRAMEWORK*, std::string const&, std::string const&, std::list<std::string, std::allocator<std::string> > const&, bool, bool) + 0x597 (comp_qexe) 0x19d7b: qexe_run_tcl_option(QEXE_FRAMEWORK*, char const*, std::list<std::string, std::allocator<std::string> >*, bool) + 0x57e (comp_qexe) 0x3e06a: qcu_run_tcl_option(QCU_FRAMEWORK*, char const*, std::list<std::string, std::allocator<std::string> >*, bool) + 0x1065 (comp_qcu) 0x1c586: qexe_standard_main(QEXE_FRAMEWORK*, QEXE_OPTION_DEFINITION const**, int, char const**) + 0x6b3 (comp_qexe) 0x3b75: qfit2_main(int, char const**) + 0xc5 (quartus_fit) 0x40720: msg_main_thread(void*) + 0x10 (ccl_msg) 0x602c: thr_final_wrapper + 0xc (ccl_thr) 0x407df: msg_thread_wrapper(void* (*)(void*), void*) + 0x62 (ccl_msg) 0xa559: mem_thread_wrapper(void* (*)(void*), void*) + 0x99 (ccl_mem) 0x8f92: err_thread_wrapper(void* (*)(void*), void*) + 0x27 (ccl_err) 0x63f2: thr_thread_wrapper + 0x15 (ccl_thr) 0x427e2: msg_exe_main(int, char const**, int (*)(int, char const**)) + 0xa3 (ccl_msg) 0x21b97: __libc_start_main + 0xe7 (c.so.6)     End-trace     Executable: quartus Comment: None   System Information Platform: linux64 OS name: Ubuntu 18.04.1 OS version: 18   Quartus Prime Information Address bits: 64 Version: 17.1.0 Build: 590 Edition: Standard Edition
Vicky1
I tried to replicate the issue with available system Ubuntu : 14.04.5 LTS & Kernel : Linux 4.4.0-31-generic with Quartus Std v17.1 but I am able to compile full design code available in quartus tool with fitter setting : "Advanced Physical Optimization" option.
which devices are you using ?
Try same design on different machine if possible or reinstall on same machine.
Best Regards
Vikas Jathar
(This message was posted on behalf of Intel Corporation)
