17253 Discussions
pls provide me verilog code for led rotate on fpga
sgulh
i have de 2 115 fpga i need led rotate verilog code
AnandRaj_S_Intel
You can achieve it with simple ring counter and delay logic.
For more information refer below logic or you can google it.
//To create the frequencies needed: // Input clock is 25 kHz, chosen arbitrarily. // Formula is: (25 kHz / 100 Hz * 50% duty cycle) // So for 100 Hz: 25,000 / 100 * 0.5 = 125 //operate the below logic from requried clock if(clr==1) q<=4′b1000; else begin q[3]<=q[0]; q[2]<=q[3]; q[1]<=q[2]; q[0]<=q[1]; end
Let me know if this has helped resolve the issue you are facing or if you need any further assistance.
Anand Raj Shankar
(This message was posted on behalf of Intel Corporation)
sgulh
thanks for reply but given code not working i tried it on google but
AnandRaj_S_Intel
Above code is not complete, you have to complete.
  1. Have you inserted clock?
  2. At what frequency your design works?
  3. What is not working in above code?
You need to work with Modelsim first and try to understand coding.​
// Quartus Prime Verilog Template // One-bit wide, N-bit long shift register module basic_rot_register ( input clk, enable, input sr_in, output sr_out ); // Declare the rotate register reg [3:0] sr; reg [23:0] count=0; reg clk_out=1'b0; // Shift everything over, load the incoming bit always @ (posedge clk_out) begin if (enable == 1'b1) sr<=4'b1000; else begin sr[3:1] <= sr[2:0]; sr[0] <= sr[3]; end end // Catch the outgoing bit assign sr_out = sr; always @(posedge clk) begin count <= count + 1; if(count == 10000000)//5hz begin count<=0; clk_out <= !clk_out; end end endmodule
Anand Raj Shankar
