17267 Discussions
Flash programming stratix V device
w_kh
While trying to program flash device, with a ,pof file, on a stratix V development board using parallel flash loader, the programming fails with error  209048 verify block 0x00000000 - 0x00000800 failure on device number 1. We are using quartus prime 18.1 standard edition. What could be the possible cause and how this issue can be resolved?
JohnT_Intel
Can you remove the verify feature in the Quartus Programmer and see if the FPGA is able to be configured successfully after power cycle?
