17253 Discussions
Floating Point multiplication problem!
Hello!
I'm trying to mult 10-bit bus with floating point constant 0.5. To do this I am using a IP FP arithmetic blocks. First - conversion 10 bit bus to 32 float, then - multiplication block (32 x 32 bits) by LPM_constant block(LPM_CVALUE = 0.5 float, LPM_width = 32) and finally - conversion to integer (from 32 to 10 bits). To check the operation I'm creating a waveform. The results is zero. Am I missing something?
--- Quote Start ---
Hello!
--- Quote End ---
if you just want to multiply by 0.5 then just discard one lsb
Multiplying by 0.5 is the same as divide by 2, which is just a 1 bit shift to the right, and discard the LSB (and/or maybe do some rounding).
Why do you want to use floating point?
LPM_Constant just drives an integer, not a floating point.
I want to be able to multiply not only by 0.5, also for example by 0.2, 0.6, 1.2, 1.5. When i click on the LPM_constant I can change the data format to float. Is this wrong?
Have you considered fixed point? the arithmatic is far simpler (it is just integer based mathematics) so the latency and resource requirements are much lower.
I think thats may be a good idea, but I dont know how to do this. I'am a newbie. Can I do this with IP cores from Quartus?
--- Quote Start ---
--- Quote End ---
to multiply by fraction you scale say by 2^10 then discard 10 lsb fro result, e.g.
0.13 => round(0.13 x 2^10) = 133
In FPGA, you multiply input by 133 then discard 10 lsbs
Thanks for help!
On the other hand. I want to add a little offset to my NCO 10 bit sin signal. Sinus is represented by samples from 500 to -500. After adding 100 signed integer with adder from Altera IP (10 bits + 10 bits) at the DAC output I get a deformed sinus - the peak is inverted.
Thanks in advance for any suggestion.
--- Quote Start ---
Thanks for help!
--- Quote End ---
Might be you are discarding MSB from result. You shouldn't.
You get 11 bits sum then you either use bits(10:1) or
(9:0) but this needs clipping(not recommended)
