Frequency Divider
Hi. Can anyone advise me on how to program a 'divide by 50 frequency divider circuit using flip flops' ? Subsequently I need to modify it to 'divide by 25 million' later. Thank you.
It should have a Input_clk, Nreset and a Output_clk. I need to know the design coding as well as the test bench coding. Thanks.
You should do your own homework assignments or you won't learn anything. Just saying...
I advise you dont go down the usual trap of creating a load of different clocks. I suggest creating clock enables instead.
Yup, it was an assignment. I managed to troubleshoot my errors already. Thank you.
