17257 Discussions
Question regarding .attrib file from compile
When I do a compile using the AOC one of the files generated is a .attrib. It looks like this
Vectorization: 1 Max_vectorization: 16 Copies: 2 Max_copies: 2 Throughput: 0.488281 Copyfactor: 3 Sharing: 1 Max_sharing: 1 Unroll: 1 Max_unroll: 1 Throughput_unroll: 1 Aggressive_unroll: 1
I've been able to figure out what most related to, but I'm not sure what the copies, max copies, and copyfactor lines mean. I believe that one or more deal with the num_compute_units attribute, but I cannot figure out which. For some of my compiles with num_compute_units (2), copies is 1 and copyfactor is 2, others have 2 and 2, while others have 2 and 3 respectively. That's where I am getting confused.
Any help would be appreciated.
