17268 Discussions
Fully Synthesizable Fix Point package
Great- I'v just learned how to use fully synthesizable floating point arithmetic calculation (using MegaFunction/IP cores). Now, how can I implement fully synthesizable Fix point calculation? I couldn't find any MegaFunction/ IP cores for that purpose…
Thanks a lot,
Idan
Fixed point aritmetic is just integer arithmetic, offset by 2^n. So no special IP is needed.
H;
Thanks alot for your quick response!
Where can I find an example for this kind of code?
Thanks againe...
Idan
in VHDL - its simple, especially if you use the fixed point package:
use ieee.fixed_pkg.all; .... signal a : sfixed(7 downto -8); -- 1 sign bit, 7 integer bits, 8 fraction bits - ie. integer offset by 2^8 signal b : sfixed(15 downto -16); ... b <= a*a;
this can all be done with the numeric_std package, but you need to keep track of the offset yourself.
Does the "fixed_pkg" is fully synthesizable?
--- Quote Start ---
--- Quote End ---
Yes. While full support only comes with Quartus Pro 16.0, you can use the '93 compatible version for compilation.
Otherwise all of this can be done with numeric_std, which is compatible with all versions of quartus.
