17267 Discussions
Function to_unsigned returns only zeros
I'm programming a FIR Filter in VHDL and I want to insert stuck on errors in the taps.. so, I did this:
SIGNAL tap0, tap1, tap2, tap3 : INTEGER :=0 ; SIGNAL error : INTEGER :=0; -- other problem if I don't initialize them with "0", the test bench won't run. SIGNAL tap3std : std_logic_vector(to_unsigned(tap3, 8)); SIGNAL tap_error : to_integer(unsigned(std_logic_vector(to_unsigned(error, 8)) or tap3std)); p1 : process begin --here I put the equations for the FIR Filter, it works perfectly if I don't try to put any errors. end process;
In the test bench I change the values in the taps and everything, but when I look the results, the tap3 signal works properly... but the tap3std is only zeros. :confused:
Does anyone know how to fix this?
Thank you,
Helder. :)
--- Quote Start ---
--- Quote End ---
In the declaration you should give the size of the vector, not the initial value:
SIGNAL tap3std : std_logic_vector(15 downto 0);
In this example tap3std has 16 bits. You can give an initial value to a signal that is a register.
The only exception are the testbenches where you can do that. This initial value is assigned in the reset condition:
process(clk)
begin
if( rst = '1' ) then
tap3std <= std_logic_vector(to_unsigned(....
elsif( clk'event and ....
instead of posting just a snippet, which is riddled with errors, why not post the real code?
Oh, hi!
I solved the problem! You're right, Tricky, I'm sorry for that. My problem was that I declared the "tap_error" signal outside of the architecture, not only out of the process. It made the signal work as a constant. Now that I changed it, it works.
Thank you, guys!
