for generate
Hi guys !
I have a problem with for ..generate
can you help me plz :
library ieee;use ieee.std_logic_1164.all; use ieee.numeric_std.all; entity cdma_testbipo is generic ( longueur : natural :=4 ); port ( clk : in std_logic ; rst : in std_logic ; data: in std_logic ; odata: out std_logic ; isis :out integer range 0 to longueur-1 ; CD :in std_logic_vector( (4*longueur)-1 downto 0) ; S :out integer range -8 to 7 ); end entity ; architecture beh of cdma_testbipo is --type Re is array(0 to 3)of std_logic_vector(0 to 15); --signal CD: Re ; type RAM is array (0 to longueur-1) of integer range -8 to 7; signal i :integer range 0 to longueur-1 ; signal code : RAM; signal idata :std_logic ; begin F:for j in 0 to longueur-1 generate begin code(j)<=to_integer(signed(CD((4*longueur)-1 downto 3*longueur))); code(j)<=to_integer(signed(CD((3*longueur)-1 downto 2*longueur))) ; code(j)<=to_integer(signed(CD((2*longueur)-1 downto longueur-1) )); code(j)<=to_integer(signed(CD((longueur-1 downto 0))) ; bpsk :process(clk,rst) begin if(rst='1')then i<= 0; else if(clk'event and clk='1')then i<=i+1 ; if(idata='0') then s<=-code(i); else s<=code(i); end if; if(i=longueur-1) then idata<=data; end if; end if ; end if ; end process ; isis<=i; odata<=idata ; end generate F ; end architecture ;
You have the process inside the generate, so the process will be generated several times. i_data, s and i are driven 4 times - you cannot do this.
Move the process outside of the generate.
Like this :
library ieee;
generic (
port (
end entity ;
signal code : RAM;
begin
F:for j in 0 to (4*longueur)-1 generate
begin
code(j)<=to_integer(signed(CD((2*longueur)-1 downto longueur )));
code(j)<=to_integer(signed(CD(longueur-1 downto 0))) ;
begin
if(rst='1')then
i<= 0;
else
i<=i+1 ;
if(idata='0') then
s<=-code(i);
else
s<=code(i);
end if;
idata<=data;
end if;
end if ;
end if ;
end process ;
isis<=i;
odata<=idata ;
end generate F ;
end architecture ;
Error : Error (10384): VHDL assignment error at cdma_testbipo.vhd(34): index 4 is outside the range (0 to 3) of object "code"
How can you correct this erreor ! plz
or like this :
library ieee;
generic (
port (
end entity ;
signal code : RAM;
begin
begin
begin
if(rst='1')then
i<= 0;
else
i<=i+1 ;
if(idata='0') then
s<=-code(i);
else
s<=code(i);
end if;
idata<=data;
end if;
end if ;
end if ;
end generate F ;
end process ;
isis<=i;
odata<=idata ;
end architecture ;
code only has 4 locations, so using 4*lonueur is going to make it try and index outside of the array.
Like this :
library ieee;
generic (
port (
end entity ;
signal code : RAM;
begin
F:for j in 0 to (4*longueur) generate
begin
begin
if(rst='1')then
i<= 0;
else
i<=i+1 ;
if(idata='0') then
s<=-code(i);
else
s<=code(i);
end if;
idata<=data;
end if;
end if ;
end if ;
end process ;
isis<=i;
odata<=idata ;
end generate F ;
end architecture ;
You can modify My programm if it's possible !
Thank you !
But if I did, how will you learn?
I told you what the problem was... you put 4* in the generate, so you either need to make the code signal 4* wider or go back to the origional version.
The code looks like a different but not lesser erroneous version of previously posted stuff. http://www.alteraforum.com/forum/showthread.php?t=45040
To mention just an arbitrary detail, you have four consecutive assignments to code(j), doing this outside a process causes a "multiple driver error". I'm under the impression that you don't know what you want to achieve at all, unfortunately me neither. I see that you are splitting input vector CD into four 4-bit signed numbers, respectively integers. But only one can be assigned to an element of array code at a time.
My suggestion, sketck the intended data flow on a piece of paper before writing VHDL.
