17267 Discussions
Optimization: If vs CASE, which one?
Hello people,
I was recently reading the ALTERA synthesis manual and I saw that the IF statement is more resource demanding than the CASE statement. In cases where we use a lone IF as in the following: (reseting a counter)
........... SIGNAL DATAREF : SIGNED(15 DOWNTO 0); ......... IF(DATAREF >= TO_SIGNED(1000,16)) THEN DATAREF<= TO_SIGNED(0,16); END IF;
Then, does it matter if we use an IF or a CASE statement?
Thanks in advance
I would challenge you to use a case statement in that code.
It really referes to muxes. an if/elsif/else tree builds a priority encoder, whereas a similar casestatement will build a simple mux. But synthesisors are getting better now, so they can work out when a load of if/elseifs are mutually exclusive and therefore build a mux instead of a priority encoder.
But unless you really care about logic usage (you probably dont with modern devices - ram and DSP usages are usually the problem areas) you should write readible code, rather than code that is really bady written but saves you a couple of LUTs.
Hey! Thanks for the answer!
The thing is that this block of code is not the only one. For example I have a protection block that takes some 32 bit values from an ADC and checks each one individually for values over a limit. So I use maybe 10 or 12 IF statements with comparison for 32 bit values. How do I optimize that?
IF(VOLTAGE >= TO_SIGNED(2400,32)) THEN
ERROR<= ERROR OR X"0A"
END IF;
IF(CURRENT >= TO_SIGNED(1400,32)) THEN
ERROR<= ERROR OR X"10"
END IF;
and so on..
I have seen somewhere that I should save the result of the comparison to a signal and then make the IF or CASE check. So as pipeling the comparison with the decision. Is it the way to go?
Thess are parallel statements, no priority involved if the results are ORed. A case construct won't represent the function.
If pipelining is necessary depends on the timing constraints, you should try.
