17249 Discussions
Generate an IP core using Quartus Standard Edition 30-days evaluation period
I have experience with other FPGA manufacturer and respective tools an now I have to send my VHDL code to other entity/person that will run in an INTEL FPGA (Stratix IV).
That entity/person has knowledge in INTEL FPGAs and respective tools but I do not intend to send directly the source code, which was written in pure VHDL.
Since in the near future I do not see that need to work with INTEL FPGAs, I was thinking the following:
To use the Intel Quartus Prime Standard Edition but just the 30-days evaluation period to generate an IP core from my VHDL code;
- Is it possible?
- Being the IP core generated with Quartus evaluation license, will the generated IP has any limitation (in period of time, or other) ? So, is it possible the to use the generated IP core forever ?
- Since, I do not intend to provide the source code, is it possible to encrypt/lock the IP core (even with the Quartus evaluation license) ?
Is there any documentation related with this issue, namely limitations with the Quartus 30-days evaluation period and the generation of our own IP cores ?
Thanks in advance.
What kind of ip core are you trying to provide. The trial version won't produce programming files or time limited IP cores.
--- Quote Start ---
--- Quote End ---
Thank you for your fast reply.
I have my own VHDL code (written in pure VHDL) which performs several specific functions of an algorithm.
I do not intend to produce programming files (bitstream), I just want to generate an IP from my VHDL code an sent it to other entity.
Then, the other entity will receive that IP and integrate it in its project/development.
The doubt is the following: with the Quartus 30-days evaluation period, am I able to generate an IP without any limitation (in time or other) ?
Therefore, my IP (generated with Quartus 30-days evaluation period) can be used by the other entity (with Quartus licensed) in the next years without any limitation, correct ?
Thanks in advance.
I think features like partial configuration and netlist generation are only available with a full licence.
Any reason you cannot just provide the source code to the 3rd party?
--- Quote Start ---
--- Quote End ---
IP protection, this is why I want to generate an IP of my VHDL code.
