16753 Discussions
Generating an ultrasonic (40 KHz) square pulse for a distance sensor with VHDL
May anyone give me a hint how to generate a square pulse with VHDL to transmit it in a transducer for a distance sensor.
Francisco.
What's your fpga clock frequency?
a-For example, if your fclk is 50MHz, count from 0 to 50MHz/40KHz=1250.
b-add a comparator to the counter: when count<625 output is '1' else '0'.
c-register the output to avoid glitches.
I is actually 50 MHz, yet I have a given clock divider so I have different possible outputs, such as: 1 MHz, 100KHz, 10KHz, 1KHz, 100Hz,and 1 Hz. Ok, Thanks
