Generic Array
What's the best way to achieve the following statement, when the user_address size depends on a generic value?
generic
addr_length: integer;
signal addr_enable: std_logic;
signal user_address: std_logic_vector((addr_length - 1) downto 0);
addr_enable <= '0' when (user_address=(others=>'1')) else '1';
Thanks!
best way to read it would be create a constant:
constant ALL_ONES : std_logic_vector((addr_length - 1) downto 0) := (others => '1'); addr_enable <= '0' when (user_address=ALL_ONES) else '1';
or you could use the AND_REDUCE function of the std_logic_misc array:
addr_enable <= '0' when and_reduce(user_address) = '1' else '1';
or the fact that the specified function is just reduced very simply:
addr_enable <= nand_reduce(user_address);
or even simpler in VHDL 2008:
addr_enable <= nand user_address;
Thank you so much!
