17254 Discussions
HLS examples in centos container
SerenaC94
I set up a centos7 Docker container to run the Intel HLS compiler (Quartus Pro 21.1). However, when I try to compile the projects from the examples directory I get the following error:
i++ -march=x86-64 tutorial.cpp -o tutorial-x86
In file included from tutorial.cpp:4:
In file included from /opt/quartus/hls/include/HLS/hls.h:22:
In file included from /opt/quartus/hls/include/HLS/internal/_stream.h:17:
In file included from /opt/quartus/hls/include/HLS/internal/_hls.h:37:
In file included from /opt/quartus/hls/linux64/bin/../../../gcc/lib/gcc/x86_64-pc-linux-gnu/9.3.0/../../../../include/c++/9.3.0/type_traits:38:
In file included from /opt/quartus/hls/linux64/bin/../../../gcc/lib/gcc/x86_64-pc-linux-gnu/9.3.0/../../../../include/c++/9.3.0/x86_64-pc-linux-gnu/bits/c++config.h:524:
/opt/quartus/hls/linux64/bin/../../../gcc/lib/gcc/x86_64-pc-linux-gnu/9.3.0/../../../../include/c++/9.3.0/x86_64-pc-linux-gnu/bits/os_defines.h:39:10: fatal error: 'features.h' file not found
#include <features.h>
1 error generated.
HLS x86-64 compile FAILED.
make: *** [tutorial-x86] Error 1
My guess is that I miss something in LD_LIBRARY_PATH, but up to now I could not find what is needed. Any hints?
AnilErinch_A_Intel
Hi ,
If you can make sure that the features.h file is present some where in the CentOS , then we can be sure that you have not missed to install any packages. Please let us know the same.
Thanks and Regards
Anil
