HOLD timing violation
I am using timequest and getting a hold timing violation. the launch clock is a 10MHz clock generated from a PLL. the latch clock is 50MHz (from which the 10MHz is derived). my logic is doing an edge detection on the "from" signal in the "to" domain. in other words, i am using the 50MHz clock to edge detect on a 10MHz signal. I do not understand why there is a hold violation. any suggestions?
thanks
kevin
You need to use synchronizer from 10 MHz to 50 MHz. Also, this is a flase path.
why would it be a false path? the 10MHZ clock is generated from the 50MHz clock with a PLL? the clocks are related.
for synchronization, i do an edge detect with the 50MHz clock on the 10MHz signal. this should be just fine. it's like sampling an asynchronous input. we do it all the time.
Sorry about false path. It should be a derived clock.
