17267 Discussions
[HPS] Peripherals Mux Table -> How to use?
Hi All,
I need some clarification regarding the Peripherals Mux Table usage. How should I understand it?
Is the First Column the Mux Output? Are the next columns the Mux Inputs?
If so, let's consider the UART0_TX signal routed by the Peripherals Mux...
According to the Peripherals Mux Table in the Qsys, there is no a matter
what Set (Set Number) is chosen for the UART0 (Set0 or Set1) -
the UART0_TX will always go to the UART0_TX pin
(see the attached snapshot).
So, how to work with the Peripherals Mux Table in the Qsys?
How to know where will a specific Qsys port be routed to?
Thank you!
Are there any response? comments? suggestions?
those with black border one is has been selected in the mux mode, you can scroll up alittle bit and there are some selection window to choose what muxing option that you need to utilize...the selection reflect the black border at the bottom.
Does selection of the Set number (Set2,Set1,Set0) affect on the device pin where the mux output should be connected?
In the https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/dp/arria-v/5asxmb3.xls, there is a column H (tab EF31), which refers to the device pin. Why?
