17254 Discussions
open CL hardware requirement
Reading the open CL guide where there is some description mention for the hardware host requirement for development purpose only , but not really stating the running hardware requirement. Is that mean any system will do as long as is able to run?
practically yes... as long as your system able to run in that operating system either win7 or linux cent os 6.5. means the hardware requirement eiter processor or the RAM has to be the minimum required to run smoothly.
this should be follow the running host system requirement
not sure if pentium II 300Mhz suitable for this?
if for window 7, i guess your system is too old... i doubt you able to install windows 7 with that box..
and.. the open cl,is not officially support Arria V? as i only see stratix V and cyclone V onward.
from altera page indeed no sign of arria V 's AOCL BSP
